Dryer Issue - Appliances - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 08:42 PM   #1
Rewards Points: 26
dryer issue
My 20 year old drier finally got to be more to repair than it was worth.
So I went and bought a speed queen drier, like you would find in a laundrymat. It is electric.
Dries like crap. Takes forever. It does get warm, and have good air flow. Anything else I can look at that might improve this?
We do always keep the lint filter clean.
blackestate is offline   Reply With Quote
Old 09-16-2011, 09:34 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
Have you cleaned the exhaust line to the outside?
jbfan is online now   Reply With Quote
Old 09-16-2011, 11:10 PM   #3
Rewards Points: 26
yes, And there is also good flow at the outside of the house.
Old 09-17-2011, 08:11 AM   #4
the Musigician
DangerMouse's Avatar
What type was the old dryer? Gas?
It may be a wiring problem?
DM
Old 09-17-2011, 08:48 AM   #5
Rewards Points: 26
The old drier was elecrtic also, and I used the same electric and same venting etc. after cleaning it. Starting to think the drier is just not a good drier, and may have to replace it again...
Old 09-17-2011, 08:58 AM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
is this a new dryer? If your vent is not obstructed in any way and does not exceed recommended run length, why not call for warranty service. I would assume it would have a 1 year warranty
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
DangerMouse (09-17-2011)
Old 09-17-2011, 11:15 AM   #7
Rewards Points: 26
They looked at it and said it was ok, And then charged me for the service call. So I am taking a shot at it before I throw in the towel.... so to speak
Old 09-19-2011, 08:09 AM   #8
Sounds like it was used dryer? who knows what someone else did before you got it? wrong thermo, screwed up wires, etc..That's a good unit and should be obvious why it's taking so long to dry. if vent is disconnected and still takes too long i wonder if the htr is getting 240vac or if someone changed one of the thermals on that htr assb and it's short cycling...if cust' tells a servicer, ie; the dryer takes two times to dry. it'll be obvious-they won't say dryers ok and collect s/c. get another opinion before you dump it.
Jacques is offline   Reply With Quote
Old 09-20-2011, 12:07 AM   #9
Rewards Points: 26
New drier. Customer service at that place sucks. I will try another one,
Flat dryer vent code??? duct Chemist1961 Appliances 3 10-24-2010 05:49 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Dryer Vent type? cbzdel General DIY Discussions 6 06-08-2010 09:17 PM
Dryer Vent Leaks Water glennonr General DIY Discussions 9 04-23-2010 08:50 AM
Dryer with no heat/House power issue Raygun Electrical 15 03-03-2010 12:26 PM
