Dryer Help - Appliances - DIY Chatroom Home Improvement Forum
Old 12-18-2013, 11:58 PM   #1
Rewards Points: 175
Dryer Help
I've got a Kenmore dryer (model # 110.60932990, http://www.searspartsdirect.com/part...od=11060932990)
I turn the knob, hit the start button, hear 2-3 clicks, and that's it -- even when I set the Control knob to air only (i.e., no heat).
The obvious potential problem: the motor or the heating unit. How would I go about testing these to see if one or the other is the problem?
Any other thoughts about how I might go about troubleshooting the dryer?
Thanks,
Richard
RichardZ is offline   Reply With Quote
Old 12-19-2013, 06:12 AM   #2
Rewards Points: 14,306
http://www.repairclinic.com/RepairHe...rt-11060932990
Old 12-19-2013, 09:40 AM   #3
Rewards Points: 350
Joe gave you a good link of the possibilities it could be.
Are you handy with a multimeter? How old is the dryer?
When you start talking about replacing motor, control board, and heating unit, they are expensive. Just don't throw a lot of money at it. You can purchase a brand new sears kenmore with warantee, no bells or whistle for around 299. Just a thought.
jmon is online now   Reply With Quote
Old 12-19-2013, 09:40 AM   #4
Rewards Points: 175
Thanks! I'll do the checks and report back.
Richard
Old 12-19-2013, 09:45 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
my first guess would be the door switch, isolate it and do a continuity check. Not likely the motor, although some Kenmore units do have a switch that keeps the dryer from running if a belt breaks( don't think yours does) the second thing I would check is the thermal fuse located on the blower housing.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-23-2013, 12:06 PM   #6
Rewards Points: 175
jmon,
I do have a multimeter, and with guidance, I can use it i.e., I may not be good, but I am teachable!).
hardwareman,
As soon as I saw the list, I smacked my forehead for not thinking of the door switch. I'm going to try that (I've been off doing other jobs ...), and I'll report back. I did try the thermal fuse and thermistor by substituting new parts, and they checked out OK (assuming the new parts are OK).
The Following User Says Thank You to RichardZ For This Useful Post:
jmon (12-23-2013)
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
