Dryer Going Out - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 10:17 PM   #16
Rewards Points: 79
So I found the problem. The outlet was on the other side of the garage from where the dryer is. There is leaves and an array of other things stuffed down the vent as far as I can see. I used a shopvac suck it out as far as it would reach but I can't reach it all so idk what to do about the rest.
mckain87 is offline   Reply With Quote
Old 11-19-2012, 07:32 AM   #17
Rewards Points: 6,652
You can get extensions or a duct cleaner that has flex rods that can be attached, so you can push the crud out of the duct.
Old 11-21-2012, 02:58 PM   #18
Special User
Rewards Points: 1,230
Hook the dryer back up the duct and turn it on, to "fluff" (no heat). Then go outside and snake the vent with a small plumbing snake. You should soon end up with blast of leaves in your face and a clear duct.
tylernt is offline   Reply With Quote
Old 11-21-2012, 03:25 PM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
Make sure you install a critter cover on that vent....that should help keep out the leaves.....
Do a search on dryer vents.
Old 11-21-2012, 05:43 PM   #20
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
There is a thing called a lint-eater sold in most hardware stores that you can use to clean the ducts. It is a 4" diameter brush that you can put on a drill to rooter out lint. You can get extensions for it so you can run it a good way through the duct, even around corners. Works well, but it sounds like you have a very long duct run.
Thunder Chicken is offline   Reply With Quote
Old 11-24-2012, 07:57 PM   #21
Rewards Points: 530
Totally agree. I have known of squirrels causing havoc at ryer vents stashing nuts and stuff.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 06:18 PM
