Dryer Extension (Outside) - Appliances - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 09:11 AM   #1
I recently had to replace my heating system. The old unit had the outside coil at the end of the unit away from the wall. The builders of the house put the dryer exhaust right over the unit, which worked fine for years other than having to clean lint off the duct covering every now and then. The new unit is an American Standard with external coils running all the way around. The dryer vent is depositing lint on the external coils that are directly facing the dryer vent.
I need to extend the vent away from the unit. Is it feasable to just run a new section of pipe through the wall so that it will extend enough to put a 90 degree elbow outside? I could then run a section of pipe horizontally and adapt a critter cover to fasten directly to the pipe instead of the house. Am I on the right track?
tbzep is offline   Reply With Quote
Old 12-08-2010, 09:17 AM   #2
Experienced
Jackofall1's Avatar
Pics would help, where are you located, if you in an area which enjoys winter weather I would be careful as to how long you extend the vent outside, as it will condensate and you will gather lint in the vent pipe eventually plugging it and possibly forming ice on the end of the vent.
Old 12-08-2010, 09:24 AM   #3
I'm at work so pics will have to come later. I'm in TN, which has fairly mild winters, but your Canadian neighbors to the north have been sending me their air all this week and I've been getting 15-20 deg lows.
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
