Dryer Exaust Vent ? - Appliances - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 08:18 PM   #1
Dryer Exaust Vent ?
Hello All, I am in the proccess of finishing my new home and have a problem. My laundry room has no exterior wall to vent my dryer. The house in on a crawl space. Any ideas would be greatly appreciated. Thanks
yelladog is offline   Reply With Quote
Old 09-01-2008, 08:24 PM   #2
The less bends the better.. can you take it below the floor and get to an exterior wall? Round metal duct would be best.
Big Bob is offline   Reply With Quote
Old 09-01-2008, 08:27 PM   #3
yes I can go through the floor, but will have to make a long run. would that be ok
Old 09-01-2008, 08:35 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
How long?
Depends.
Use metal (aluminum = best) flex duct only.
Good luck.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-01-2008, 08:47 PM   #5
50 - 60 ft to take were I would like to take it. I could take it closer but the foundation is really low in that area. 50-60 ft to get to the back of the house where the foundation is much higher
Old 09-01-2008, 09:06 PM   #6
How about a roof top exhaust?
I just installed a bathroom fan with a roof vent. I would suggest that a dryer vent would be much the same.
If you live in a frosty area, the pipe must be insulated to prevent condensation from forming and running back inside.
Old 09-01-2008, 09:10 PM   #7
I wonder if the lint would stop it up
Old 09-01-2008, 10:03 PM   #8
I would say that there would be less a problem, than with a 60' horizontal run.
From time to time, it may be necessary to vacuum the pipe out with a Shop Vac.
Hopefully, it would be a straight up, vertical run.
Dryer vents do require cleaning on a regular basis!
Dryer Exaust Vent ? yelladog HVAC 5 09-01-2008 08:32 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Flexible gas line and dryer vent? kcrossley2 Plumbing 5 05-05-2008 12:31 PM
Dryer vent and AC compressor - min. distance? RDS HVAC 5 05-04-2008 07:50 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
