Dryer Drum Turning But No Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 03:24 PM   #1
New owner, older house
Dryer drum turning but no heat
we had the heating element and the 2 thermostats tested--and they're good. I reset the breaker too. what else can be the problem??
Whirlpool model LER5620KQ1
thanks in advance for any words of wisdom
Taz38 is offline   Reply With Quote
Old 02-26-2010, 05:54 PM   #2
ojc
ojc's Avatar
Repair Clinic
I had this happen twice. Once it was just a faulty leg on the 240VAC. I reset the switch and away it went. The other was a bad fuse.
Sorry I can't help more.
good luck
ojc
ojc is offline   Reply With Quote
Old 02-27-2010, 08:46 AM   #3
thx--we tested the thermal fuse and it's reading. the only other thing we haven't tested is the timer motor. Taking that in today. I'm stumped. The breaker isn't a "double breaker" with 2 switches, its one larger than normal size breaker with one switch--I reset it (I don't know the technical term for the bigger breaker--sorry!). Still nothing.
fixing to run out and buy a new one!!
Old 02-27-2010, 12:16 PM   #4
welp changed out the breaker and tested the timer--everything running as normal--except still no heat.
stumped!
Old 02-27-2010, 12:19 PM   #5
Rewards Points: 1,442
Have you measured the voltage to be sure you are getting 240 volts inside the dryer? There are a variety of places you need to test, including around the timer motor where a number of connections are.
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 09:47 PM
Stripping Latex Paint....Help! DanielleEglsNst Painting 6 10-22-2008 02:13 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
No heat gas dryer fireguy Appliances 3 11-18-2007 10:46 PM
