-   -   Dryer drum turning but no heat (http://www.diychatroom.com/f47/dryer-drum-turning-but-no-heat-65429/)
Taz38 02-26-2010 02:24 PM
we had the heating element and the 2 thermostats tested--and they're good. I reset the breaker too. what else can be the problem??
Whirlpool model LER5620KQ1
thanks in advance for any words of wisdom
ojc 02-26-2010 04:54 PM
Repair Clinic
I had this happen twice. Once it was just a faulty leg on the 240VAC. I reset the switch and away it went. The other was a bad fuse.
Sorry I can't help more.
good luck
ojc
Taz38 02-27-2010 07:46 AM
thx--we tested the thermal fuse and it's reading. the only other thing we haven't tested is the timer motor. Taking that in today. I'm stumped. The breaker isn't a "double breaker" with 2 switches, its one larger than normal size breaker with one switch--I reset it (I don't know the technical term for the bigger breaker--sorry!). Still nothing.
fixing to run out and buy a new one!!
Taz38 02-27-2010 11:16 AM
welp changed out the breaker and tested the timer--everything running as normal--except still no heat. :censored:
stumped!
AllanJ 02-27-2010 11:19 AM
Have you measured the voltage to be sure you are getting 240 volts inside the dryer? There are a variety of places you need to test, including around the timer motor where a number of connections are.
