Dryer Does Not Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 12:10 AM   #1
Rewards Points: 150
Dryer does not heat
My old dryer is still blowing air, but it is no longer hot air. When I looked under the heating element I saw that one of three springs has broken. This spring was attached to a wire that is white with red stripes. How do I reattach the springs?
Cossack is offline   Reply With Quote
Old 08-24-2011, 01:09 AM   #2
Rewards Points: 6,652
You have to purchase a new heating element. Those are not springs, they are elements.
Old 08-24-2011, 06:15 PM   #3
Rewards Points: 150
So I can't just solder the two elements together? All three elements are in a small but long metal box. I donít see how to open it to replace the broken element. Are they sold together?
Thank you for the help. I do not know a lot about this, but I want to save some cash.
Old 08-24-2011, 06:23 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You have to remove the whole box and replace the whole box with a now whole box. That assembly is your heating element in its entirety and there is no fixing it. You cannot solider it, you cannot splice it, you cannot crimp it, you cannot tape it, you cannot twist it.
Somewhere around 84 dollars should replace it. Whatever you do don't call a serviceman.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (08-24-2011)
Old 08-24-2011, 07:46 PM   #5
Now Bud, what if they call for service, and a female shows up? Is it then okay for that person to do the job?
Old 08-24-2011, 08:03 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I said: Don't call a serviceman.
A service-woman would be okay.
XXX
Old 08-27-2011, 01:23 AM   #7
yes i totaly agree with the you ...You have to purchase a new heating element. Those are not springs, they are elements.
Huntsville Home Improvement
albert15 is offline   Reply With Quote
Old 08-28-2011, 06:56 AM   #8
Whatever you do don't call a serviceman.[/quote]
OR- go to a doctor, dentist, car mech, any other pro, yada yada. they might see something or know something that you wouldn't even think of or recognize- since it's not 'what you do for a living'. an example would be a previous post on "what are these metal strips on my dryer"-beyond that the OP probably has a bad vent-potential fire-witness the blackened burner assb. he's prob not aware of the danger-a service PERSON would check all that. maybe there's charred wires in there that he wouldn't be cognizant of.. oops!!
Jacques is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Whirlpool electric dryer won't heat jpplumber Appliances 5 01-13-2008 10:21 PM
No heat gas dryer fireguy Appliances 3 11-18-2007 09:46 PM
