Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 09:47 AM   #1
dryer
why does the dryer vent hose keep detaching
dutch67 is offline   Reply With Quote
Old 02-24-2011, 10:35 AM   #2
Rewards Points: 84
The dryer is rocking, the discharge is plugged or restricted, or the hose is bad. So...
Check that the dryer is setting on all 4 feet, and is level front to back and side to side.
Remove any lint from the dryer to the point of dischage.
Inspect the flapper at the discharge to ensure that it is free.
Now, as for the hose, if it is a vinyl one, throw it away and replace it. There are hoses available, but I always use rigid 4" metal duct and elbows, with foil tape, and have not encountered any installations in which it was necessary to use anything less. All you will need is a pair of tin snips to cut the duct to lenght. Do not screw joints together, as they will collect and hold lint.
Old 02-24-2011, 05:29 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
is there a clamp on the vent hose?? it needs to be clamped or it will come off if you are using a hose and not metal.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 06:18 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 08:16 PM
