dryer
my dryer is not drying the cloths at all. the flame comes on for 7 to 10 seconds and shuts off then never comes back on. took it apart and cleaned it and that didnt help. the dryer is only 3 years old.
I assume you are talking about a gas dryer.. Check the vent for obstructions. There are coils on top of the gas valve that go bad.
yes a gas dryer,sorry. i will check that out thank you
it has a glow plug but i will check and make sure everything is tight.
everything is tight, when i first turn the dryer on it works for about 10 seconds and then the heat shuts off. in order to get it to come back on i have to open the door wait for a couple of mins and then it will work again for a few seconds
took the whole thing apart and clean everything out, didnt help
Sounds like the holding coils are bad. on top of the gv. Sometimes you can hear them chatter
is there any way to check the gv?
if it comes back on after you stop it for a bit, sounds like it's cycing on hi-limit. if coils are bad the igniter will cycle on and off w/o flame. you either have flame problem- dirt/spider/on orfice or the air flow is restricted, either inside the dryer vent or outside vent. pull tube off dryer-good air flow out? run dryer with vent disconnected-caution**CO is present**now ok?
you didn't post your brand or model/serial# but if this is electronic controled the problem may be there.
If your pilot flame keeps going out, chances are you will need to replace the pilot latch assembly, also make sure the vent hood flapper is closing ok and no outside air is blowing in effecting the pilot flame. That’s my guess...
After checking with my appliance repair brother his bet is your holding coil on your gas valve is bad as others have suggested.
| All times are GMT -4. The time now is 03:36 AM. |
