Dryer 3 Prong To 4 Prong Wiring Question - Appliances - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 08:58 PM   #1
Question
Dryer 3 prong to 4 prong wiring question
I searched for a how to on here and found a great one.
Please help, changing dryer cord from 3 prong to 4 prong
On the diagram I have figured out the green wire connects to the frame where I unhooked it and capped it\replaced with green from new plug. So where the green one was connected on the block is where the white one from the new plug goes. However the wire combined with the green one coming off the block into the dryer was dark blue, not white. On the block it has L1, neutral (white/was green) and L2. The diagram on this forum is showing L1 is the Black wire and L2 is the Red wire. However on the other side of the block, coming off and going into the dryer it is showing different. Coming off the block L1 is a red wire and L2 is the black wire. So I don't know whether to follow the L1 and L2 labels or the wire colors coming off the block into the dryer. The 3 prong that came off is only gray. It had no colors to follow.
Brand name is HotPoint. Heavy duty large capacity 3 cycle.
neondeception is offline   Reply With Quote
Old 05-01-2012, 09:04 PM   #2
Rewards Points: 6,652
If you have the book for the appliance, it will give you info on 3 & 4 wire hook ups. If you want more, post a picture of your situation.
Old 05-01-2012, 10:01 PM   #3
The block is in the dryer and difficult to see the wires coming off. Couldn't get a good picture unfortunately.
Old 05-02-2012, 06:55 AM   #4
Rewards Points: 1,300
L1 and L2 are the hot leads. They can be any color accept white and green. White is always neutral and green is always ground.
danpik is offline   Reply With Quote
Old 05-02-2012, 09:46 AM   #5
So it red and black can be on L1 or L2 in any order?
Old 05-02-2012, 10:11 AM   #6
Yep. You can even jump up and done and drink a cold one. It does not matter because it is straight 240vac.
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Wiring Help, Changing a Dryer and/or Stove circuit to something else shunut Electrical 10 01-08-2011 03:06 PM
Wiring for new 220V Dryer question nycguy Electrical 19 01-08-2011 12:30 AM
Basement wiring question kupalino Electrical 8 11-14-2009 09:25 AM
Dryer wiring tmiles2246 Electrical 33 05-13-2009 05:19 PM
