Double The Water In Frig - Appliances - DIY Chatroom Home Improvement Forum
Old 11-21-2009, 11:46 PM   #1
Double the water in frig
I have a KitchenAid ktla22elss01 refrigerator.
It has a water dispenser inside the refrigerator and an automatic ice maker that dumps ice in the freezer. The ice maker works fine.
The problem is when I press the button inside the frig to get a cold glass of water not only do I get a cold glass of water but water also flows into my ice maker as long as I hold the button. For some reason both of my solenoids (ice maker and water dispenser) are being energized when I press my water dispenser button. I looked at the wires and nothing seems shorted out, or out of place . I even took the hoses off of my valve inlt and watched water shoot out of both valves when the button was pressed.
Is there some sort of isolation valve I need to replace? I noticed one metioned in the schematics.
Any help would be appreciated. We are tired of getting huge blocks of ice in our ice bin.
Joe B
j0eb is offline   Reply With Quote
Old 11-23-2009, 08:34 AM   #2
you need to call a servicer, otherwise you're going to start throwing parts at it. you may have transducence at the valve, bad valve, i/m, switch's, etc.
Jacques is offline   Reply With Quote
Old 11-23-2009, 08:46 AM   #3
i just looked at schematic. you probably have shorted diodes.
Old 11-23-2009, 04:22 PM   #4
Thanks Jacques is that a part I can order and replace?
Old 11-25-2009, 07:23 AM   #5
it's avail from Fridigaire as a separate part. from Whirlpool you may have to buy wiring harness.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Water Pipe Size for Double Shower froddan Plumbing 12 08-03-2007 09:46 PM
