Dorm Fridge In A Wall - Appliances - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 07:34 PM   #1
Rewards Points: 150
Exclamation
Dorm Fridge in a Wall
Is it ok to put a dorm size fridge in a wall?
It is this model: http://www.amazon.com/Sanyo-SR-2570M...863213-0203945
If so How many inches in the back should there be of air space?
Thank you.
Mijotter is offline   Reply With Quote
Old 05-04-2013, 08:39 PM   #2
Nearly all fridges have their "coils" built into the side walls nowadays. This means you need to leave about 2cm space each side. The compressor tray will stick out from the back of the fridge enough to give you enough air gap behind (don't have it hard against the back due to vibration.) Allow at least 1cm above to let the water vapour out.
rbenseman is offline   Reply With Quote
Old 05-04-2013, 09:01 PM   #3
Rewards Points: 6,652
Thank you.
All of it. Unless the unit is rated to be placed inside an alcove, it needs as much air as it can get, to help cool down the coils, if they are open on the back of the unit. Reading the remarks on the unit, it appears that it is a pretty loud unit. Placing it into an alcove, will only enhance that noise and make it even louder.
Old 05-04-2013, 09:55 PM   #4
Rewards Points: 150
Ok so small opening at the top between fridge and wall and about 6 inches opening in the back from back of fridge to back of wall...
Old 05-04-2013, 10:26 PM   #5
It is still going to be a loud unit. If you have a restaurant supply house in your area, that resales refurb equipment, that would probably be better than one of those cheap throw aways that you are looking at. There are a few compact commercial coolers, that are pricier, but made for being placed inside cubbies, and most will be not as noisy, unless you get a fan that when it is running, knocks against the guard.
Tags
dorm , fridge , refridgerator , wall
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
