Doors Of Fridge Removed To Go Into Kitchen? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 03:16 PM   #1
Rewards Points: 278
Doors of fridge removed to go into kitchen?
I only have 32" opening entering the kitchen. The body of the fridge I am going to order, is 28.25" deep without the door, but the depth with door even without handles (33" ) and width (32.5") is getting to be too tight. It's a french door and bottom freezer drawer.
Can all of the doors and drawers be removed in order to move into the kitchen? Or am I only restricted to buy 29-30" fridges?
Thanks in advance
DIYGST is offline   Reply With Quote
Old 01-12-2009, 03:54 PM   #2
Normally your hinge caps pop off and you undo hidden bolts from above and below. Check to see if there are Ice or water lines involved. Electrical would generally detach with plugs. If your drawer rolls out, it comes out somehow, but best to find out how easy in adavance
Chemist1961 is offline   Reply With Quote
Old 01-12-2009, 05:06 PM   #3
I just had a new fridge installed. The delivery guys had to remove the doors on the new and old fridge. They said they remove the doors all the time. As DIY said, the caps pop off and you may need to disconnect water and electical. There are probably quick disconnects already in place to facilitate easy removal.
beerdog is offline   Reply With Quote
Old 01-12-2009, 05:12 PM   #4
Rewards Points: 278
That's good to know, thanks
how long are the power cord usually on the fridges? because I just built an enclosure for the fridge about 30" deep, but want to make sure it can be plugged in and pushed into the cavity. Of course, I am trying to avoid extension cords for this.
Old 01-12-2009, 05:38 PM   #5
bradnailer's Avatar
Sometimes, you can just open the doors, angle the fridge through the door then close the doors back when you get the fridge through the opening. That will normally work when you have a straight shot a the door and room on either side of the door. I always try that method before removing the doors.
bradnailer is offline   Reply With Quote
Old 01-12-2009, 07:24 PM   #6
Rewards Points: 109
Usually the cord is 3-4'. Tie a piece of string (dental floss) to the cord's middle after you plug it in. Drap the string over the top of the fridge and hold some pressure on it to keep the cord off the ground. This will keep the wheels from hitting it and will allow you to push it all the way in.
Daltex is offline   Reply With Quote
Old 01-12-2009, 08:26 PM   #7
Learning by Doing
Leah Frances's Avatar
It's pretty easy to take doors off a fridge. To get our new fridge in the house this Sat they have to take the doors off the fridge as well as the doors off the entrance to the house.
Measure everything twice - they got the fridge in the kitchen only to discover it was 0.50 inches too wide for the enclosure! HALF AND INCH! Thankfully, we could tear down the enclosure and it fit between the cabinets with mms to spare.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Steps to lacquering my kitchen cabinet doors? Bacardi 151 Interior Decorating 7 05-04-2007 09:00 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
