Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-28-2009, 03:14 AM   #1
TCK
Question Does anyone know if this repair man is telling the truth?
My LG was not always emptying the water completely. Leaving just a bit of water in the bottom,but would empty if I spun it again.
I had the repair man look at it and it worked ok at the time, he said there could be a blockage in the hose and would have a look.
Now the pump is not working at all and he has said that this can happen after cleaning the hose out the pump just dies. I wish he had never touched it!
Could this happen? Is it worth fixing we have already spent $170.00 on repairs with the same guy.
Should I just forget it and buy a new one??
TCK is offline   Reply With Quote
Old 10-28-2009, 10:48 AM   #2
Whether he is telling the truth is sort of irrelevant at this point but I doubt he did anything that would cause a total pump failure. It was probably shot and once water flow was restored may have just given out.
You are $175 into an old machine already and by the time you buy a new pump and pay for labor to put it in (another $250-300 or so?) you will have a more substantial chunk invested. I am not one for throwing things away if they can be fixed but there comes a point where it is just not practical to fix them. Depending on how many miles you have on the whole thing, and how high end your model is, you might think about a new one if such is in your budget. On the other hand if none of the rest of it is showing any signs of problems a pump fail is fairly common and you could be good to go for quite awhile after it is replaced.
sdsester is offline   Reply With Quote
Old 10-28-2009, 01:06 PM   #3
TCK
Unhappy
I have been thinking that way as well.Just buy a new machine and count my loss. It just annoys me that before he touched it the machine was still working.
Old 10-28-2009, 01:47 PM   #4
TCK
Unhappy
[quote=TCK;346490] The pump was working most cycles and just leaving a small amount of water with some of the cycles and would empty when I respun.I don't know how it could just completly die.
Anyway thanks for your thoughts,I have been thinking that I should just buy a new machine and count my loss.
Old 10-28-2009, 01:53 PM   #5
TCK
Unhappy
The pump was working most cycles and just leaving a small amount of water with some of the cycles and would empty when I respun.I don't know how it could just die.
Old 10-29-2009, 10:05 PM   #6
whatever was blocking the pump from draining all the way is now inside the pump. take apart the pump (3/4 screws) and remove whatever is in there... maybe just a lint buildup. If you take it apart and find something in there then *bam* your done... if you don't see anything in there then try rotating the impellor inside and see if it moves. if not then go buy a pump yourself and put that bad boy in. save some $$$ hope this helps
ibzbro is offline   Reply With Quote
Old 10-29-2009, 10:58 PM   #7
TCK
Thanks for your help. I ended up ringing them back to put in a complaint and they came out and fixed it for free. They said the guy who looked at it the fist time was young and still learning but they would stand by their workmanship. For Allmakes Central Coast looking after their customers.
Old 11-04-2009, 08:42 AM   #8
WOW! they should be your servicer for life. LG is an expensive appl. and requires special training and tools. they will cost more to repair. there may have been something in the pump[which would have been obvious] or it may have been a bad pump to begin with[common]. in either case they didn't owe you a completely free repair. hope you will tout this servicer to your friends.
Jacques is offline   Reply With Quote
More On This Topic
All right. The next thing that we have to do, as we are communicating these thoughts and feelings and ideas to our partner, is we must engage in productive communication. It is not productive to do the blame game, which is what we just talked about. That... Read More »
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Alright, let's put all this stuff on. First thing we have to do is take off the existing water pump... Read More »
Hi this is Howard Fleischmann with Community Tire in Phoenix, Arizona on behalf of Expert Village. Once everything is back together underneath the vehicle and you've checked and double checked your work to make sure everything is in place and secure. And... Read More »
Add Tofu to Fruit Soup
Add Tofu to Fruit Soup by Expert Village
We're going to add some tofu to the soup base. Now you're saying tofu? Maybe you're saying tofu? Or maybe you're saying tofu! Because your not going to be able to taste this tofu in there. It's going to add a nice creamy texture without adding a lot fat... Read More »
This example, I'm going to do a riff basically based on the key of E minor again. Except, I'm going to use more of a scales in it and playing muted over a simple drum beat. Again, something that was really started in the eighties and kind of disappeared... Read More »
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 10:43 PM
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 19 08-02-2009 03:54 PM
Repair Compounds saggdevil Painting 2 07-04-2009 10:10 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 07:49 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 1 01-07-2008 04:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
