DIY Refrig In Process HELP! - Appliances - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 02:52 PM   #1
DIY Refrig in process HELP!
Bottom freezer works, top fridge warm (no air). Read posts on here.
Took back cover off back of bottom freezer. Fan and duct to top OK.
BUT, freezer coils all frosted up. Fan comes on/off with thermostat.
Defrost these? How much frost is acceptable on the coils?
Thanks!
Bill7 is offline   Reply With Quote
Old 10-02-2010, 03:54 PM   #2
So I took my daughters hair dryer and carefully defrosted everything. LOTS of ice. I now remember the freezer was left open a bit last week sometime. I suppose that is where the ice came from???
Anyway, going to plug it in. Oh, unit is only three years old.
Old 10-02-2010, 09:12 PM   #3
Put everything back together, turned it on.
Both fans come on...
After I went out to mow, came back in and the upper frige part was at 32ish. Hopefully I solved the problem!
Old 10-03-2010, 04:28 PM   #4
Rewards Points: 472
Thanks!
No frost should be build up on the coil's. I bet the defrost coil is bad. If solid you can thaw them out for the time being. but they will frost over again. Call some one that can check out the defrost heater. good luck
del schisler is offline   Reply With Quote
Old 10-03-2010, 05:31 PM   #5
HVAC / Plumbing
when in defrost check for power. If power is ok. OHM them with vm
kenmac is offline   Reply With Quote
Old 10-03-2010, 07:23 PM   #6
OHM them with vm
So far so good today. If it frosts up again, I will know something is up...
Would the freezer being stuck open over night contribute to the frosting of the coils?
Whirlpool refrig. problem ken1415 Appliances 147 02-25-2017 12:27 PM
Anyone here built or in the process of building with SIPs? Badfish740 Building & Construction 1 09-30-2010 09:20 PM
new process or product for re staining or painting wood cabinets efox Painting 1 11-20-2009 03:35 PM
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 11:37 AM
Home building process wilddngy General DIY Discussions 19 04-06-2005 02:17 PM
