-   -   DIY Refrig in process HELP! (http://www.diychatroom.com/f47/diy-refrig-process-help-82884/)
Bill7 10-02-2010 02:52 PM
Bottom freezer works, top fridge warm (no air). Read posts on here.
Took back cover off back of bottom freezer. Fan and duct to top OK.
BUT, freezer coils all frosted up. Fan comes on/off with thermostat.
Defrost these? How much frost is acceptable on the coils?
Thanks!
Bill7 10-02-2010 03:54 PM
So I took my daughters hair dryer and carefully defrosted everything. LOTS of ice. I now remember the freezer was left open a bit last week sometime. I suppose that is where the ice came from???
Anyway, going to plug it in. Oh, unit is only three years old.
Bill7 10-02-2010 09:12 PM
Put everything back together, turned it on.
Both fans come on...
After I went out to mow, came back in and the upper frige part was at 32ish. Hopefully I solved the problem!:thumbsup:
del schisler 10-03-2010 04:28 PM
Thanks!
No frost should be build up on the coil's. I bet the defrost coil is bad. If solid you can thaw them out for the time being. but they will frost over again. Call some one that can check out the defrost heater. good luck
kenmac 10-03-2010 05:31 PM
when in defrost check for power. If power is ok. OHM them with vm
Bill7 10-03-2010 07:23 PM
OHM them with vm
So far so good today. If it frosts up again, I will know something is up...
Would the freezer being stuck open over night contribute to the frosting of the coils?
Thanks:thumbsup:
