Diswasher Draining - Appliances - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 12:17 AM   #1
Rewards Points: 99
Diswasher draining
Dishwasher draining a lot of water through the sink drain by the faucet.
Is this normal? If not, what do I need to do to fix it?
Thanks.
kirwinjd is offline   Reply With Quote
Old 02-08-2013, 12:25 AM   #2
Rewards Points: 13,274
Confusing post.
Do you mean it's backing up in the sink?
If that's it then clean out the trap under the sink.
Run a snake down the drain with the trap and tail piece off.
Old 02-08-2013, 12:33 AM   #3
Rewards Points: 99
Originally Posted by joecaption
Confusing post.
Sorry. I'm trying to remember the fitting that is mounted on the porcelain sink that the dishwasher drains to. But isn't there a also a primary drain that is tied into the sink drain?
Old 02-08-2013, 12:38 AM   #4
Rewards Points: 99
Sorry. I'm trying to remember the name of the fitting that is mounted to the porcelain sink above. Looks like a vent or overflow for the dishwasher. That's where a lot of water is pouring out of. Isn't there a also primary drain under the sink that the dishwasher is tied into? I just don't remember seeing that much water pouring out of the upper drain before. Thanks for responding
Old 02-08-2013, 12:41 AM   #5
http://www.bing.com/images/search?q=...lectedIndex=28
Without a picture of what you have we would have to guess how yours is plumbed.
Old 02-08-2013, 12:49 AM   #6
Rewards Points: 99
Ok. Thanks a lot. I'm a good HVAC mechanic but I suck when it comes to appliances.
Old 02-08-2013, 09:01 AM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
still kind of confused here, but it sounds like your dishwasher is tied into an airgap above sink? and it is leaking here? You need to be a little more specific with what your problem is.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-08-2013, 09:30 AM   #8
custom user
Rewards Points: 150
Are you sure the cap is not loose and screwed on tightly?
JasperST is offline   Reply With Quote
Old 02-09-2013, 05:08 PM   #9
Rewards Points: 3,130
The fitting mounted on the sink is most likely an air gap. Its purpose is to prevent dirty water from siphoning back into the dishwasher. If it is pouring out water, you almost certainly have a clog somewhere.
Old 02-15-2013, 01:44 PM   #10
Rewards Points: 99
Thanks all for the input but that wasn't the problem. Like the Einstein that I am, I failed to remove the plug for the dishwasher drain inside the garbage disposal that I replaced a few months ago. (Sorry I forgot to mention that).
Now if you'll excuse me, I need to catch a plane to Stockholm where I'm receiving the Nobel prize for quantum physics.
Old 02-15-2013, 02:40 PM   #11
custom user
Rewards Points: 150
Glad you got it figured out! Geez, a few months of that? You must have been washing by hand. Or using paper plates, lol.
Kitchen sink not draining, is it the vent? gdav Plumbing 18 02-12-2013 04:38 PM
Question re draining heating expansion tank Rav HVAC 4 11-19-2012 10:53 AM
Washtub draining into floor drain DIY? Because we LOVE you Plumbing 2 08-26-2008 10:48 AM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 11:33 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 10:19 PM
