Disposal Loud. - Appliances - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 12:26 AM   #1
Rewards Points: 99
Disposal loud.
Replaced my garbage disposal only about 6 months ago and it sounds like its flying apart. The old one did too. Any suggestions?
Thanks a lot
kirwinjd is offline   Reply With Quote
Old 07-06-2013, 05:30 AM   #2
DIY staff
Rewards Points: 7,174
Have you remover it and cleaned out the insides? Most often the racket is caused by some foreign object ----pennies,screws and broken glass are frequent culprits.
Old 07-06-2013, 10:35 AM   #3
Rewards Points: 99
No, I haven't removed it to check. I've only put my hand down there and felt around. Didn't find anything.
Old 07-06-2013, 10:55 PM   #4
Rewards Points: 918
My money is on a small spoon.
Remove.
Turn upside down.
Shake vigorously.
Collect whatever comes out.
Replace.
Repeat as necessary.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
kirwinjd (07-07-2013)
The age old disposal issue - high drain hyunelan2 Plumbing 12 02-21-2013 06:20 PM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 12:39 PM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 07:24 AM
