Dishwater Not Draining - Appliances - DIY Chatroom Home Improvement Forum
Old 03-04-2014, 08:50 PM   #1
Rewards Points: 61
Dishwater not draining
Bought this in October 2013, so it is still under warranty, but wanted to see if the symptoms could be a fouled line or if it is something else.
It is a Frigidaire FFBD2411NB1A
It has been working for the last few months, until today...and it isn't draining... When I start the drain cycle, it gurgles a little, then stops and the motor just hums. I took apart the insides down to the little drain hole and it was all clear, nothing found in the strainers...
any ideas?
thanks,
Jeff
jeffeg is offline   Reply With Quote
Old 03-04-2014, 08:54 PM   #2
Rewards Points: 20
Check the drain line. There might be a clog in it.
Dan
djlandkpl is offline   Reply With Quote
Old 03-04-2014, 09:00 PM   #3
Rewards Points: 256
Alot of times it's something caught in the pump, or a bad pump.
michaelcherr is offline   Reply With Quote
Old 03-04-2014, 09:50 PM   #4
Rewards Points: 61
I wonder if it would be worth my effort to pull the unit out and take it all apart or just call in the warranty?
Old 03-05-2014, 07:44 AM   #5
Rewards Points: 29
There are alot of reasons a pump will not pump. It will be one of these.
1. The intake, where the water flows to the pump, is blocked
2. The impeller on the pump is loose
3. if the impeller is an enclosed style the veins may be blocked by something.
The discharge is blocked by a kink or plug in the discharge line.
4. The intake of the pump has a crack where it can suck air.
5. If the pump is cavitating, it will just spin and not pump. Cavitating is where one of the above things have happened and the pump just spins. If it continues for a long time it will ruin the pump.
4reel is offline   Reply With Quote
The Following User Says Thank You to 4reel For This Useful Post:
DIYRemodeler (03-11-2014)
Old 03-05-2014, 08:09 AM   #6
Rewards Points: 986
I once bought a new DW because of a not draining problem. Pulled the old one out and could see the discharge hose had developed a kink. New one on the pickup tail gate so went straight ahead like a charging bull moose. Gave the old one away to a young couple just beginning a family that surely needed it. It's still running and I've since replaced the one on the tailgate twice.
Old 03-05-2014, 10:06 AM   #7
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
One problem that I have found.
every now and then a homeowner will replace the disposal without removing the knockout plug for the dishwasher drain.
Otherwise as previously mentioned check the hose for kinks and plugs.
gmaint is offline   Reply With Quote
The Following User Says Thank You to gmaint For This Useful Post:
Old 03-05-2014, 10:41 AM   #8
any ideas?
thanks,
Jeff
Diffinately check out the obvious. It may be something simple like a kink or clogged line as others have suggested. If no results, I agree with you, go the waranty route and swap it out for another one.
jmon is offline   Reply With Quote
Old 03-11-2014, 01:01 AM   #9
GetYourShineBox's Avatar
if its not even trying to drain at all its usually the drain solenoid. this was a very common problem with i did maintenance. its what you hear click before the dishwasher starts draining into the disposal. if you take off the bottom door plate its usually right there attached to a plate in front of the pump. check the picture for example.
GetYourShineBox is offline   Reply With Quote
Old 03-11-2014, 01:01 AM   #10
you can usually tell if its bad just by looking at it.
Kitchen sink not draining, is it the vent? gdav Plumbing 18 02-12-2013 03:38 PM
Question re draining heating expansion tank Rav HVAC 4 11-19-2012 09:53 AM
Washtub draining into floor drain DIY? Because we LOVE you Plumbing 2 08-26-2008 09:48 AM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 10:33 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 09:19 PM
