Dishwasher Wood Floor - Appliances - DIY Chatroom Home Improvement Forum
Old 01-06-2015, 07:38 AM   #1
Rewards Points: 44
Dishwasher wood floor
Can anyone recommend an installation method which will help *deter* water damage from a dishwasher onto wood floors?
My idea is to create a pan or a small 'pool' underneath my dishwasher as to help avoid water leaks into the rest of my kitchen.
The next, more abstract idea is to put one of those things that makes a loud noise when a child wets the bed underneath
(New wood floors being purchased, thinking long term protection...)
thanks
dmsniwbty is offline   Reply With Quote
Old 01-06-2015, 09:55 AM   #2
Rewards Points: 4,514
? How's rising that floor going to effect being able to even get the washer in place under the counter top?
A couple of ideas.
1, Have them lay the flooring until just under the visible area at the front of the washer, then use plywood for the rest of the floor and cover with glued down linoleum.
2, Any real HVAC shop can make you a pan out of galvanized metal in a few min.
If it was mine I'd want a 3 sided pan so if it did leak I'd know it because the water would show at the front of the pan.
PS, wood flooring in a kitchen is not the best idea.
Old 01-06-2015, 10:18 AM   #3
ZZZZZ's Avatar
Rewards Points: 712
There are battery-powered water leak detectors out there. Just do a search at Home Depot or your other favorite store.
ZZZZZ is online now   Reply With Quote
Basement Floor Leveling Prior to Wood Install Curmudgeon10 Flooring 14 12-28-2014 09:29 AM
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Cupping of wood floor, need input Vlreddick Flooring 52 10-17-2012 05:48 PM
new wood floor and dishwasher height issue bublsort Flooring 2 07-09-2011 08:29 PM
Best nail hole wood filler for hard wood floor Radjack Flooring 4 04-16-2009 08:17 PM
