Dishwasher Won't Run - Latch Sensor? - Appliances - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 09:45 AM   #1
Rewards Points: 77
Dishwasher won't run - latch sensor?
Loaded up the dishwasher earlier, turned it on, and nothing. After troubleshooting some of the basics, I noticed that if I put pressure on the door, the dishwashing cycle will begin, as soon as I take my hand off, it will stop. This leads me to believe that it is a problem with the latch...I assume the dishwasher will not activate until it is securely latched.
However, the door shuts just fine...If the door is closed, I can't open it even a crack by pulling on the door without the latch...seems like it is properly shut to me.
Not sure how old the unit is but I estimate it to be 7-10 years old...just a wild guess though. It is a Kenmore...
Anyone have any luck with something like this in the past....should I just start looking to replace it with a newer model. A dishwasher is really not something I want to mess around with due to any potential water hazards..or electric for that matter...
elementz is offline   Reply With Quote
Old 08-03-2011, 12:40 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
probably a door latch switch out of adjustment or going bad, may have to open it up to see if it can be adjusted or most likely replaced. Model# would help to tell you what you need to do.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-06-2011, 09:33 AM   #3
Rewards Points: 77
Here are a couple of pictures.
Probably can't tell much from this one but it is a picture of where the door latches...I can't see anything out of the ordinary here. The door itself latches to it just fine and is stable when closed
Uploaded with ImageShack.us
Here is the info tag....I tried a quick search of that model number but it didn't return anything relevant.
Old 08-06-2011, 01:41 PM   #4
#1 HAWKEYE FAN
to see the problem you will have to take the inner door panel off, exposing the latch assy. It should have 2 micro switches on it.
Old 08-06-2011, 06:42 PM   #5
Rewards Points: 77
Do you mean the door itself or the actual inside panel you see when the door is open
Old 11-04-2015, 07:15 PM   #6
Rewards Points: 12
I know this is an old thread, but I have the same problem with my Whirlpool dishwasher (model DU890) as elementz's dishwasher. It's about the same age (made around 2003) and the problem just started a few weeks ago. The cycle starts fine but stops midway. If I press on the door near the latch, it starts again. But, I need to keep pressing it or else it will stop running. I understand hardwareman's point about taking the inner door panel off to inspect the latch, but what would I be looking for once I get the panel off? How would I know if it's the latch or something else causing the problem?
BCH_COLIN is offline   Reply With Quote
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Maytag dishwasher latch - hard to open Betty Hurley Appliances 0 08-29-2010 04:18 PM
Occupancy Sensor: Did I wire it correctly? kohaiut Electrical 7 01-14-2009 11:13 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
