Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-17-2007, 10:11 PM   #1
Dishwasher won't drain......
So we've got a new Kenmore dishwasher (less than a year old)....havn't had any problems until this last cold snap. I'm assuming that something has froze, since the weather has been the only variable to change since we've used it.
Basically the basin is full of water but will not drain. We've tried to run teh drain cycle a few different times with no luck....just seems to cycle the water, but not get rid of it.
Any ideas of where to start???
thanks in advance.....
ryanVT is offline   Reply With Quote
Old 12-18-2007, 06:53 AM   #2
Is this on an exterior wall?
redline is offline   Reply With Quote
Old 12-18-2007, 07:23 AM   #3
It is, but the supply comes off the kitchen sink lines, and the drain connects as well.
It's 110+ old farmhouse.....I doubt as well that there is any insulation to be found. Maybe some settled sawdust which i've found in other walls
Old 12-18-2007, 08:23 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
If the sink is draining and just the dw has a drain problem, then the problem is in the dw pump or drain line most likely. Remove the dw bottom panel and put a heat lamp directed at it on the floor (pump) and open the sink base cabinet doors to allow warm air in to see if it helps thaw anything to start it again. Drain water, if all is O.K. is only "solid" in traps. If the sink isn't draining either, you might try a hair dryer on the trap.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-18-2007, 09:54 AM   #5
Thanks Mike,
I'll be headin' home to throw some heat on it for the afternoon. Is it possible the pump is "burnt" out after running but nothing happening??
Hopefully there'll be some progress this afternoon.
so i went home for a quick lunch and decided to pop the bottom panel and pull the drain line. It emptied the basin into a reseviour (yes i didn't forget about that)....so i figured it wasn't frozen in the unit. I pulled the connection into the kitchen drain and tried blowing through the line but couldn't.......ding ding*...must be frozen. Set the heat on it and will check it later this evening when i get back.
Old 12-19-2007, 07:32 AM   #6
....it apparently thawed out......and she works now .
Now on to the root of the problem!!!
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Dishwasher don't drain all the way MattCoops Appliances 8 04-17-2007 11:07 PM
Dishwasher Drain Question kypper Plumbing 2 01-16-2007 12:39 AM
