Dishwasher Water Temp - Appliances - DIY Chatroom Home Improvement Forum
Old 08-09-2008, 12:40 PM   #1
I just purchased a Kenmore Dishwasher (Model 665 1359K600-made by Whirlpool) and contrary to the users manual, it does not heat the water to 140 F while in "Hi Temp Wash" mode. At best, the temperature only goes up to 118 F. The users manual recommends that water be 120F as it enters the washer--->mine is not and since I'm in a condo, I've no way of controlling that.
I purposely purchased this machine because the old one didn't heat the water at all and my glasses were coming out cloudy. Though marginally better, I'm still not satisfied with the results from this one. I have a rinse aid, I've tried different detergents and adjusting the amounts. The water hardness is 11 grains.
Has anyone else had this experience? Does anyone have any suggestions (or better yet, some magic tricks) or is this a lost cause?
I've put a call out to Sears, but they can't come until next week.
Janet is offline   Reply With Quote
Old 08-09-2008, 01:33 PM   #2
My Kenmore owner's manual suggested something I've not seen elsewhere.
Before the cycle begins you run hot water from the nearest faucet so when the dishwasher fills at the beginning of a new cycle, the water is already hot.
But, our Kenmore doesn't have the problem.
We had the "cloudy problem" with our KitchenAid DW, and it did all the preheating and such. This symptom was not mentioned in the factory service manual that I bought for this machine. We never solved it. Maybe it was hard water, but our Kenmore is not doing this.
Maybe it was a problem with the water supply and it has been fixed. They started adding orthophosphate to the water to prevent pinhole leaks in copper pipes; maybe the symptom and the additive are related.
Your water company might be able to help you with this, free of charge, if you contact them. They have an interest in the purity of the water, so they might even analyze what this film on the glassware is, for you.
Old 08-09-2008, 02:01 PM   #3
Thanks for the tip vis a vis running the water before starting the washer...unfortunately I've already tried that and it doesn't work. As for the glasses, it's not so much that they're cloudy, it's simply that they don't get altogether clean (I like to drink coffee out of clear mugs and the 'rings' left by the coffee don't come out) and I'm thinking that's because the water isn't getting hot enough.
In part, what I'm wondering, is whether the service people can somehow tweak the machine to heat the the water more? Also, I'm wondering whether the machine is a lemon or whether it was never designed to work with water below 120F?
Old 08-09-2008, 05:53 PM   #4
The rings have to be scrubbed out. I don't mind leaving them in the cups but my wife doesn't like them much.
The machine has to be designed to heat the water; maybe yours is, but the heater/thermostat is kaput.
Before spending $$$ I'd turn up the water heater to 130F if there are not people in your house especially vulnerable to burns. Exposure for 30 sec to liquid at 130F can burn anyone, according to the Shriners research.
If there are letters on your water heater thermostat instead of numbers, the people at the heater manu's 800 number can tell you what temperatures the letters represent.
Old 08-10-2008, 07:53 AM   #5
Are you sure about the water supply temp? Hot water that you can just hold your hand under is about 125 degrees, water that is above 150 will cause cleaning problems such as the glasses that are cloudy and may leave food particles on them. If the glasses look clean when wet but cloudy dry that is called etching which is to much detergent and water to hot. If the water is to hot you can have a mixer installed at the supply line which will regulate the temp.
CIT1336 is offline   Reply With Quote
Old 08-10-2008, 08:23 AM   #6
Can you post a link with more water temp effects info? DW cleaning problems seem to be common.
Is it
too much detergent and water too hot
or
too much detergent or water too hot
Old 08-10-2008, 08:42 AM   #7
To hot water and to much detergent is the problem. If the temp is ok usually 1/2 to a full cup of detergent will do the job, remember dishwashers are indoor lawn sprinklers. Upper rack not cleaning can also be caused by loading, don't put glasses over prongs which allow them to hit together and may break only rest against the prongs to allow tops to drain. You can try washing without detergent if you think the water is to hot, then if it seems better add detergent a little each load till the problem returns.
Old 08-10-2008, 12:59 PM   #8
[quote=Yoyizit;147348]The machine has to be designed to heat the water; maybe yours is, but the heater/thermostat is kaput.
Do you suppose there is some sort of thermostat /sensor in the machine?
I purposely purchased this machine because it has a high temperature wash option and furthermore, that it would heat the water to 140F regardless of the temp of the 'source' water. Unfortunately, this does not seem to be the case.
I'm certain the water is not too hot having measured the temp at various stages of the wash cycle and found it has been below 140F. The glasses are not etched, they clean up fine by hand though I am playing around with the amount of detergent. Because the water here is considered quite hard (11 grains), it is my understanding that hot water and extra detergent are essential to clean properly...though at this stage, I'm essentially washing clean dishes to test whether the machine is gonna live up to my expectations---->I've had it less than a week.
I guess that what I'll really have to do is see if I can contact a service technician and find out if there is some sort of thermostat/sensor that can be adjusted. Otherwise, I'm hooped.
I'll keep you posted...and thanx for the input!
Old 08-16-2008, 10:02 PM   #9
Well...to answer my own questions, Sears came out today to look at the dishwasher. Yes, there is a sensor in the motor which will trigger the heater to either turn on or off depending on the intake water temperature. No, the sensor cannot be adjusted to heat the water more. There would be no point replacing the sensor because it is not broken. I guess I'm scrubbing those rings out by hand. The end. Thanks to everyone for their input.
Old 08-17-2008, 06:50 AM   #10
ccarlisle's Avatar
Dishwasher detergent formulations can contain a number of ingredients, from just one or two for the cheaper brands, to a half-dozen for the brand-named products like ElectraSol etc. Try changing brands and see what happens.
Some will have phosphates, some not; some have replaced phosphates with zeolites...and all these ingredients have an effect on cleaning your dishes in your machine in your city. Also look into rinse aids, then report back.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Adding a new water line to dishwasher and fridge? PMichaud Plumbing 18 01-05-2007 07:00 PM
Dishwasher - top rack no water pressure jbomber Appliances 5 12-18-2006 04:49 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
