Dishwasher Soap Dispenser Not Opening - Appliances - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 04:54 PM   #1
Rewards Points: 296
Dishwasher soap dispenser not opening
Our dishwasher soap dispenser does not want to open on its own during the wash cycle. I had the interior door panel off once as I was trying to fix some noise it was making. I think the problem may have begun sometime after that. I am wondering if maybe I caused the problem. I guess my question is how does the door flip open on its own anyway? I assumed it was water pressure from the spray arm and thought maybe an overstuffed load was blocking that but I am not sure. Is there a heat sensor that releases it or some other timing mechanism?
Eagle One is offline   Reply With Quote
Old 11-18-2011, 06:37 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
depends on make and model but most use a small wax motor to open them
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-19-2011, 06:58 PM   #3
Rewards Points: 296
I have a Kenmore Ultra Wash diswasher and the model number is 665.15705891. Can anyone confirm how this soap dispenser operates? The manual I have is useless.
Old 11-20-2011, 05:44 PM   #4
#1 HAWKEYE FAN
that model will use a cam on the timer to pull a plastic linkage that runs down to the cup. If you took the inner door off I can guarantee you did not get it put back together right.
Old 02-08-2012, 11:23 AM   #5
Rewards Points: 296
Ok, so I opened up the door again to see if I could tell what I did wrong but I did not see anything obvious. I am not even sure if I have the missing cam or not. I am attaching two pics. The first one is something that looks like it could be the cam and the other is a pic of the inside of the door (the top edge of the photo is the right hand side of the dishwasher if you were looking at it). If this part is indeed the cam, I don't have a clue where it goes!
Does anyone have a diagram of this model or something that could help me see what is missing and where it belongs?
Dishwasher soap dispenser not opening-000_0580.jpg   Dishwasher soap dispenser not opening-000_0577.jpg
Old 02-08-2012, 11:46 PM   #6
#1 HAWKEYE FAN
when you pulled the door panel off you pulled the actuator bar off of that little arm that hangs down from your timer. When the timer advances it pulls that arm up and pulls up on the actuator. Its really kind of tricky to get it back together.
Old 02-09-2012, 01:48 PM   #7
Rewards Points: 296
So the first pic is NOT something that belongs in the dishwasher? I don't even know where that came from. My wife found it in the kitchen....
Where is the timer located (near the top, middle, bottom)?
Old 02-09-2012, 08:02 PM   #8
#1 HAWKEYE FAN
no, I do not recognize that thing in the first pic. Timer is right hand side of control panel
Asko Dishwasher Dispenser came with Different Connections momfxit Electrical 0 09-16-2010 06:33 PM
dishwasher air gap and soap dispenser silkyblue4 Plumbing 1 09-17-2009 11:58 AM
Help with soap dispenser! Mr.Merle Plumbing 2 07-11-2009 10:10 PM
white stains improvements Appliances 1 02-20-2009 05:26 PM
stinky black pipe opening behind dishwasher... ripnlip Plumbing 1 08-01-2008 01:35 PM
