Dishwasher Replacement - Appliances - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 09:04 PM   #1
Dishwasher replacement
Hi everyone-
How difficult is the replacement of an old dishwasher for a new one? This is for a rental property I have, and I've never done any plumbing before. If it's easy enough I'd give it a shot but don't want to risk doing it wrong since it's not my own residence. I was thinking of buying a $200 model and don't want to spend $150 getting it installed. Thanks a lot!
-Greg
c00rdb is offline   Reply With Quote
Old 01-24-2010, 09:29 PM   #2
I replaced mine fior rental last year. I too opted for $200 model and saved on deliver/install by doing mysefl.
The instructions were pretty thorough and the install was pretty easy. Do you have disposal?
make sure you measure the space, ensure new d/w is level and depending on age reverse the removal of old for install. My biggest issue was with inlet and the diff btwn the old and the new. I had to buy a new elbow I believe...
Good luck!! Save the money and DIY!!
Han'D' is offline   Reply With Quote
Old 01-25-2010, 12:12 AM   #3
Too Short? Cut it Again!
They are usually pretty easy. You might have to buy some plumbing connection kits. But no big deal. Do measure so you get the right size though.
Old 01-25-2010, 08:59 AM   #4
Household Handyman
Rewards Points: 1,408
One thing I would advise you on: Look to see if new flooring has been added since the last dishwasher was installed. I ran into this last Oct. The homeowner had a "Pergo" type flooring installed in the kitchen which raised the floor level up about 5/8" or so. The old dishwasher was at it's lowest level also. I had to get them to agree to allow me to either remove one section of laminate c'top or to try and jack it up on that end. I'm glad the dishwasher was placed near the end. I was able to use a jack and push the c'top up enough to get the old unit out and the new unit in. I also advise to get a dishwasher hose kit (or whatever they are called), with the braided flexible hose for installation. This makes it so much easier than trying to retro-fit and old copper line. Good Luck, David
Thinking about installing a dishwasher kossuth Appliances 1 09-23-2009 10:05 AM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 08:19 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
