Dishwasher Not Draining Whirlpool - Appliances - DIY Chatroom Home Improvement Forum
Old 03-12-2017, 01:34 PM   #1
Rewards Points: 18
Dishwasher not Draining Whirlpool
Hey all,
WHIRLPOOL WDF310PAAS4 It is low end basic machine. All cycles work but the drain. So far I have checked filters, hoses, floats etc...
No errors on the CONTROL PANEL
However, when you PRESS CANCEL/DRAIN button, nothing happens:
One would think you hear the PUMP try to at least turn on, even if it is plugged/ Or at least click or something? Or maybe the pump is fried because it was plugged and burnt out it's solenoid?
My next step is manually draining the water and unhooking from A/C but I was hoping for a bit of input.
Thank you much in advance.
zipwood is offline   Reply With Quote
Old 03-12-2017, 01:39 PM   #2
Rewards Points: 358
Re: Dishwasher not Draining Whirlpool
Same thing zipwood. Click on link and see if that helps you any. They have complete testing and how to videos to help you.
https://www.repairclinic.com/RepairH...shwasher-Parts
jmon is offline   Reply With Quote
Old 03-12-2017, 02:01 PM   #3
Rewards Points: 18
After a little more research, I have a new question:
Does a DISHWASHER have one or two pumps?
It appears to me that ONE PUMP is used for BOTH pumping the wash sprayers and one for DRAINING. If I am correct then if my pump is cycling the wash sprayers but not the drain, I am back to thinking it is the drain valve jammed or drain solenoid burnt out.
Please do not respond with links to appliance parts ads!
thanks in advance
Old 03-12-2017, 05:56 PM   #4
Rewards Points: 284
Some dishwashers have two pumps, some don't. Yours is one that has two pumps. If you have an amp meter measure amps when you turn on drain cycle. If it measures roughly 1 amp your motor is either stuck or bad. I would look for a obstruction before I would I would buy a new pump. Those motors jam pretty easily.
BayouRunner is online now   Reply With Quote
Old 03-13-2017, 12:45 AM   #5
Rewards Points: 18
Thank you for your reply. Two pumps makes sense for sure! I am getting the client to "cup out" the water so we can get it reasonably dry before we tip it up to clear/test that Drain Pump. Hopefully it is just something jammed.
Old 03-20-2017, 01:19 AM   #6
Rewards Points: 18
I have fixed this LOW END DISHWASHER unit and for sure confirm (per BayouRunner) it does have TWO pumps. One pumps the SPRAYERS and the second pumps the drain. My issue was there was a large piece of a wine glass stuck in the impeller of the drain pump. It took quite a bit of careful effort to get it out, but it seems to be working fine now. The client is lucky that the pump did not burnout as looking at "the snap together pump assembly" gave me the impression that it was probably a difficult part to repair. It is sad that these unit are designed to be so throw away! Not to mention is the question of how a piece of wine glass that was at least 1.5 x 1 inch got past the filters in the first place?!
WOW! Anyhow, I contributed by saving this modest family's $$ and saving yet another pile of junk from the landfill.
Below shows us trying to get the glass out from the pump:
Whirlpool dishwasher does not dry dishes homenewbie Appliances 3 11-19-2015 06:24 PM
Whirlpool dishwasher not draining completely Lemkie Appliances 8 10-27-2015 10:24 AM
Whirlpool gold dishwasher not draining all the way Gburg109 Appliances 3 03-26-2015 08:17 PM
Whirlpool dishwasher not draining JoeLena Appliances 2 05-03-2013 03:38 PM
Help Dishwasher Draining Problem swicks15 Plumbing 2 09-21-2008 12:58 PM
