-   -   Dishwasher Not Draining (http://www.diychatroom.com/f47/dishwasher-not-draining-160850/)
karsat 10-22-2012 03:28 PM
Hi,
My dishwasher is not draining water...water still staying in it....
Can someone help in giving some ideas Please
user1007 10-22-2012 05:16 PM
Usually something is clogged in the drain tubing. I once got a mushroom stem, the exact same size as the ID stuck and had trouble clearing it.
It could also be a pump failure? Does it make noises like it is trying to pump out the water? Does your dishwasher drain through a garbage disposal? That is how the mushroom stem got in the tubing on the one I mentioned.
allthumbsdiy 10-22-2012 09:03 PM
model & make? did you check to see if a breaker was tripped?
karsat 10-22-2012 10:23 PM
It's ge and btw I do hear the sound but dish washer stop once it can't drain.
ddawg16 10-22-2012 10:48 PM
One of the common problems is the 'chopper'. It's a disk that is driven by the motor....it chops up food as it's being pumped through the washer....the shaft is typically plastic. If it hits a hard piece of food....it can break....
The first symptom is that your dishes are starting to not be so clean....eventually the food plugs up the pump.
jfrotten 10-23-2012 10:50 AM
Take the bottom panel off. In the middle you will see a box with what looks like a fan in it. Take a screw driver and try to spin it with the screw driver. If you do this with the dishwasher on it will usually break free in abou 1/4 turn.
notmrjohn 10-23-2012 12:03 PM
" If you do this with the dishwasher on..." you could electrocute yourself!!! Don't go poking around with a screwdriver or anything else with the washer on or even connected to live wire. Turn off breaker before taking any part off. I don't think you're going to need to take the bottom panel off anyway. If problem is pump or connections you'll have to pull unit out from under cabinet.
There is more than one model of GE, each is slightly differant. Google Appliance Parts, enter your model number at one of the sites, look for schematic diagram of your model. You should see how to get to choppers, strainers, hoses etc to see if they are clogged. Be careful working in there, there are some parts held in place by surprisingly flimsy clips, breaking one of them can mean replacing a very expensive part. ( Voice of experience here, solving a similar problem I broke one little tang, part of $90 dollar part. Took some clever inventing to fix it. I was trying to remove lower arm, turned out I didn't need to in first place to remove screen over "chopper."
From description, " I do hear the sound but dish washer stop once it can't drain." Sounds like, screen, chopper or something B4 pump could be clogged, pump needs water to cool itself, water isn't getting to it so it shuts down. Or doesn't sound like, if you prefer, indicating same thing. Easy to fix from inside tub, screen and chopper area just get gunked up.
But do not go tearing into it without looking up model number and looking at schematic, at least post model number here. Might be same as mine. I can tell you how to get to places, I can sure tell you what not to do. Do NOT try to remove lower arm, without more info.
Once you get gunk cleaned out, run a cup or two of vinegar thru a cycle in empty washer once a month or so. Gunk is grease, food bits and even undisolved washing detergent. Vinegar disolves it out. Oddly enough liquid detergents seem to gunk up more than powders.
Post model number.
Jackofall1 10-23-2012 12:17 PM
Have you checked the drain inlet screen at the bottom of the washer to ensure its not covered?
SeniorSitizen 10-23-2012 01:31 PM
I had a Whirlpool that didn't drain well so I bought a new one. The day I changed it out I found the problem. After 4 years for some reason the drain hose got a kink. New one went in and I gave the old one to a young couple that needed it. I'm on my second one now and as far as I know the one I gave away is still cleaning dishes.
notmrjohn 10-23-2012 02:04 PM
1 Attachment(s)
Does yours look like this?
Aside from red ring, that's part of my invention, plastic jar lid instead of $90 part.
karsat 10-24-2012 01:17 PM
GE model number is GE PDW7880N10SS
karsat 10-24-2012 01:18 PM
I tried vinegar/baking soda/hot water nothing helped so far.
notmrjohn 10-24-2012 04:52 PM
You have different model than mine. Problem may be same, clogged drain chamber or filter sump.. I can't tell you exactly how to get to yours, they look somewhat similar. look here, drawing 2 http://www.a-1appliance.com/lookup/180755/1294478 Parts 506 and 508, cover and sump filter. My cover was held on with screws, looks like yours clips on, be careful, look it over good, those little clips break easily and both parts are $20 each. Siphon, sponge, shop vac all water out. If you think you can, take cage like cover off and filter out and clean. Get water out of sump and see if it is gunked up, or tubes leading to or from it are clogged. Long handled bottle brush to clean them.
( Drawing 5 shows sump, drain lines, and pump assembly. If sump/outlet end is not problem it may be at inlet, down center of part 454 drawing 5. You will have to remove lower arm to get to it. My arm was held on with hidden tabs and that's what I broke. I do not know how yours is held. Some have a large thumbscrew in center, some arms unscrew if tuned against normal direction. Mebbee somebody here knows how to take that arm off without breaking something. But if pump is working and arms are spraying, I doubt problem is at that end. Infact, disregard all this in blue, I'm more or less thinking out loud and looking ahead. )
Part 325 drawing 5 is drain assembly, if sump is clean inlet to it may be clogged, assembly may not be working, or drain from it may be clogged. You will have to slide unit out and check back side for kinked or clogged hose and outlet from drain assembly. If you are worried about breaking little clips or can't figure out how to remove parts, do this first B4 cleaning sump. I do not know if you have a check valve if not, you can hold hose down low and pour water thru sump. If water comes thru clog is upstream from sump. If not problem is downstream or you have electric check valve. Try filling only sump with water and running washer briefly.
If none of these, or other's relativly easy remedies work, it may be problem with drain assembly. about $50 to replace yourself.
user1007 10-24-2012 05:26 PM
Other thing to keep in the back of your mind, and I hate the concept I suppose. Of all appliances, dishwashers are about the least expensive and near the lowest in terms of technology. You cannot justify bringing someone in for a service call to fix one and buying the insurance beyond the warranty makes no sense (it does to the sales person on commission and the store because they make more on the warranty than the machine!).
Unless you need one with $5 extra sound insulation translated to an extra $100 retail or one that senses whether humans or pets have licked dishes in them? Or blinks pretty colored lights to convince you it knows? Or your water heater does not work so you let your dishwasher heat some up?
They are so cheap to replace do not fuss too much with one that has any mileage on it.
They are also the second most conceptually stupid appliance in a kitchen. In nice kitchens I have done for clients I have distributed dishwashing and refrigeration. Why open 800,000 cubic feet of space to grab a soda or stick of butter. INSANE and energy wasteful. Why have some giant thing for all dishes from crystal to pots and pans? Same cycle.
And you know what. When you get rid of the concept of big ugly appliances you can move several smaller ones around in "drawers" and never have to worry about making cabinets to fit around the design concept that dates back to when ice blocks were delivered again. You can make them work better and faster with regard to what is in them too.
notmrjohn 10-24-2012 05:48 PM
For a few years my Dad did make readies on FHA and VA repo homes. One of first things done was removal of dish washers, garbage disposals, water heaters, anything plumbed or hard wired was part of hose and had to be guaranteed by Govt. Water heaters were replaced but we had succession of dish washers. Least little thing wrong out it went replaced by another one.
Only time I've had repair man in house was on recall on dishwasher, replace wiring harness. But then I was able to replace $90 with jar lid. The washer was free. Friends bought a new one, had tiny ding in side when delivered. Sears brought out new one, didn't take old one. They notified Sears twice, kept it for nearly a year, got tired of it being in garage, told me to come and get it.
kar, this may be easy to fix, it may not be worth risk of breaking something, and paying to fix that, plus chagrin when repair man pulls mushroom from hose.
