Dishwasher Not Completely Filling - Appliances - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 11:54 PM   #1
Rewards Points: 518
Dishwasher not completely filling
Folks have a 7 year old Frigidaire Dishwasher model # FDB126RBS2. It is having trouble filling the tub. Water still flows in but not even 1/4 of the amount that is supposed to and then continues on it's cycle like nothing is wrong. The sound of the water flowing sounds obstructed. I have verified that the water supply including the shutoff valve and the water line are not obstructed. Does this sound like a fill valve issue?
n0c7 is offline   Reply With Quote
Old 07-04-2012, 02:30 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
and you know it is not filling with the proper amount of water how? Newer dishwashers. especially the frigidaires, use a very small amount of water to wash.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-04-2012, 02:49 PM   #3
Rewards Points: 518
It's an old model that used to fill up with I would say 10 liters and now only fills with about 0.5 liters. This is not an efficient new model.
Old 07-04-2012, 04:28 PM   #4
#1 HAWKEYE FAN
that would still be a water efficient dishwasher, but 1/2 litre is not enough water. Replace the water valve if the inlet screen is not plugged up.
Old 07-04-2012, 11:23 PM   #5
Rewards Points: 83
Sounds like the water valve isn't allowing enough water through as said above. you could take it out and try and clean it, but best bet is to just replace it. If there are other deposits inside the unit. Run a few cycles with a bunch of vinegar in the tub. That will help break up + clean any deposits.
Protocol. is offline   Reply With Quote
Old 07-04-2012, 11:33 PM   #6
Rewards Points: 518
Replaced the valve and the issue is resolved. Thanks guys!
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
No hot water in kitchen and dishwasher is not filling water lol Plumbing 3 09-07-2010 12:47 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
