Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-31-2008, 09:18 AM   #1
Dishwasher noise on fill
I recently installed a new dishwasher, replacing a very old unit that I was told hasn't worked in 10 years. The problem is that when it initially goes to fill with water it makes a sort of thrumming sound (very loud). If I turn on the hot water at the sink a little the sound goes away. Does the dishwasher have a pressure regulator of some sort and thats what I'm hearing? I dont know what our house pressure is, I still have to check that.
Grimace is offline   Reply With Quote
Old 03-31-2008, 01:28 PM   #2
What you have is condition called "Water Hammer" it is cause when the water flow is suddenly stopped.
There are a devices called a water hammer arresters that can be installed in the water lines to stop the hammering.
girltech is offline   Reply With Quote
Old 03-31-2008, 02:18 PM   #3
Wouldn't I have had this problem at the faucets and such before the new dishwasher was installed? And where in the system would I have to install an arrester?
Thanks!
Old 03-31-2008, 02:43 PM   #4
Doesn't sound like water hammer. Sounds like harmonic vibration. The flow of the water is matching the frequency that a stretch of your pipe wants to vibrate at. When you change the flow by opening the sink valve you change the water flow to a different speed that doesn't match the pipes vibration frequency.
Try putting something on the pipe that is vibrating to dampen the vibration. It may also be vibrating against the wood where it passes through a framing member.
If you have a valve on the dw supply line you might try adjusting it slightly to affect the water flow rate.
Old 03-31-2008, 03:00 PM   #5
Hi grimace
The valve on the dishwasher closes faster then you turning the tap off so it still could be water hammer.
Old 03-31-2008, 03:03 PM   #6
I'm gonna try closing the valve on it a little tonight and see if that works.
Thanks!
Old 03-31-2008, 03:07 PM   #7
Originally Posted by girltech View Post
Hi grimace
Would it be normal for the valve to open and close several times a second during the fill? Because its not just a single noise, it lasts for several minutes during the fill.
Old 04-01-2008, 12:30 PM   #8
The pipe will rattle for a little while if it is water hammer.
The valve will only open and close once per fill.
Old 04-01-2008, 12:48 PM   #9
Thats why I don't think it is water hammer. The noise starts as soon as I hit start and lasts the entire fill (later in the cycle also when it refills).
I tried throttling the supply valve last night and it did stop, but only when the valve was almost entirely shut.
Old 04-01-2008, 02:04 PM   #10
When you installed the dishwasher did you use copper water line?
Is it vibrating against something?
Or is the noise right in the valve?
What is the make and model of your dishwasher?
Did you find out what your water pressure is?
Old 04-01-2008, 03:02 PM   #11
Still sounds like harmonic vibration to me. Turn it on and figure out which stretch of pipe the sound is coming from and put something on it to dampen the vibration or change the frequency it vibrates at. If it's buzzing in a framing hole squirt a dab of caulk in the hole.
Old 04-02-2008, 10:27 AM   #12
Well I fixed it but not sure what it was I did.
I removed the fill valve and flushed the supply line (3/8-copper). Took apart the valve and cleaned out the inlet screen but it was pretty clean as it was, and rinsed out the inlet and outlet sides of the valve really good. It fills quiet now.
On to the next little project! My house to-do list is like Earl Hickey's except I add more stuff than I can cross off.
Thanks all!!
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General Discussion 10 01-31-2008 06:51 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 05:28 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
