Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-16-2009, 11:45 PM   #1
Dishwasher mounting?
On our kitchen remodel our counters are coming this Weds. Just today the installer asked if the dishwasher was onsite, so they could "mount it to the underside of the counter.
Our appliances will not be in until the following week.
The counter co. said we could also mount it to the side of the cabinets.
Is either a better way? seems that mounting it to the counter could damage the counter if you ever needed to pull it out for any reason.
I've never heard of this at all.
Advice, suggestions?
troyce1 is offline   Reply With Quote
Old 02-17-2009, 07:09 AM   #2
Remodeling Contractor
Dishwashers are always mounted to the countertop. No damage will occur if properly installed. They are also optionally attached to the side cabinets, but not usually done.
Old 02-17-2009, 07:19 AM   #3
Screws are used on the mounting brackets which are easily removed should the unit need to be pulled out for repair or replacement.
A competent appliance installer should be well versed in the details.
Revue is offline   Reply With Quote
Old 02-19-2009, 06:09 AM   #4
if this is a stone counter-top, don't install at top. it won't hold, even if they use epoxy etc to mount studs... depends on what brand, consult installation papers. some have access holes on sides but if installer overtightens, the tub will bow and d/w will leak. there is also a kit that installs on frame underneath avail. if c/t is drillable ie; corion,wood,etc then screw to top. that's the best method.
Jacques is offline   Reply With Quote
Old 02-19-2009, 07:41 AM   #5
SDC
SDC's Avatar
Not necessarily true. My granite/stone guys drill holes and plug them, then fasten dishwasher as usual. I have done them this way for years, never a failure. I do agree if you just use epoxy, it will not last for long.
SDC is offline   Reply With Quote
Old 02-19-2009, 08:53 AM   #6
can't argue with success. your guys are evidently top notch. i however find many times these plugs work loose. the remodeler is long gone and the cust now has another problem.
Old 02-19-2009, 09:52 AM   #7
We epoxy a double 1/4-20 nut into granite. Never heard of one coming out. The feet are adjusted up and tight, so not much force is exerted on these except a slight perpendicular force to prevent tipping.
Old 08-06-2012, 10:55 PM   #8
Yep, I was plagued with a mysterious leak for over a decade. I think it is because we were using side clips to mount 2 separate dishwashers. Over five pros have been to the site to diagnose the problem. I've replaced the same section of flooring in the kitchen 3 times, had the plumbing under the sink rerouted, threw out the first dishwasher that was probably just fine, made other suggested repairs.... Finally, the last repair person removed the side clips, and I think that was the problem all along.
So here i am trying to figure out how to stabilize the dishwasher since the countertop is granite. Those side clips are evil.
landgirl is offline   Reply With Quote
Old 08-07-2012, 05:04 AM   #9
Chicago, IL
Michael Thomas's Avatar
Originally Posted by landgirl View Post
Yep, I was plagued with a mysterious leak for over a decade... \
What brand(s) were the dishwashers?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 08-07-2012, 08:13 AM   #10
Amana and now Kenmore.
I'm off to find some type of floor mount to hold in in place.
Old 08-07-2012, 10:03 AM   #11
Chicago, IL
Thanks. Added to my notes.
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Adding a dishwasher with no pre-existing cabinetry for d.w. gsk3 Remodeling 7 01-25-2009 01:59 PM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 09:19 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 05:28 PM
