Dishwasher Lights Going Crazy - Appliances - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 04:38 PM   #1
In a little over my head
Rewards Points: 706
Dishwasher lights going crazy
I'm hoping someone has seen this before. I have a 3-4 year old Kenmore dishwasher (Made by Whirlpool. Don't have the model number right now.) Stainless steel, moveable shelves, quiet, an upper end model. It's got the electronic membrane style switches and LEDs on the front of the door. It will sometimes stop mid-cycle, and the display LEDs will start blinking in crazy patterns. Not random, but not making sense either. Sometimes, pushing a button will change the pattern, but even the Cancel button won't reset it. Sometimes, pulling the fuse and letting the machine sit with no power for a while will reset the lights, sometimes not. Sometimes it works fine.
The control box has been replaced. It seemed to be fixed for a month or so. Now it's doing it again.
Any ideas? I like the dishwasher when it works, but another repair will put me pretty close to the original purchase price. And I sure don't want to fix it and have it still broken.
Thanx!
ratherbefishing is offline   Reply With Quote
Old 05-24-2011, 08:16 AM   #2
Usually when they blink it's a fault code-#of blinks tells you what area fault is in. behind the bottom panel is a tech sheet with the fault codes. otherwise sounds like touch panel shorted. after it's fixed you have to let it run through a diag cycle to reset the computer-wonder if this was done last time? procedure is on tech sheet.
Jacques is offline   Reply With Quote
Old 05-24-2011, 09:01 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
yeah sounds like a shorted touch pad, like Jacques said grab the tech sheet and put it into a self diagnostic test.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
DRIVING MYSELF CRAZY over dimming lights! wbsdiy Electrical 8 05-13-2011 09:37 PM
Lights Blinking on Frigidaire Dishwasher used2beatech Appliances 3 01-25-2010 08:09 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
