Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-19-2012, 09:04 PM   #1
dishwasher leaving soapy residue
We own an old maytag jetclean DAY9906BAB dishwasher. Recently it has been leaving soapy residue on some plates and especially on glasses up top. Seeing as the holidays are are here and money is tight does anyone have any troubleshooting suggestions? Thanks!
ryanm83 is offline   Reply With Quote
Old 11-19-2012, 09:49 PM   #2
JOATMON
ddawg16's Avatar
First thing to check is the air valve on the sink....make sure it's not blocked. It's that thing sticking up on the back side of the sink that seems to not have any purpose. If you look under the sink, you will see it tee's into the drain hose for the washer.
Next....if your seeing food in there as well, I'm going to say that your chopper is bad. Connected to the pump is a disk that turns with the pump....all the water is pulled through this disk that basically looks like a disk with holes in it....it's purpose is to chop up the food so that it will go down the drain without damageing the pump.
It's not unusual for the chopper to get a bone or something hard in it and the shaft breaks.
If you pull off the kick plate, you should find the schematic on the back side. And the internet has a ton of info on how to pull the machine apart.
When I replaced mine, I think the part was like $26.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-20-2012, 12:03 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
first thing to do is remove the filter on top of the pump, I can almost guarantee it is plugged or partial plugged. Remove the spray arm then remove the four screws in the pump cover, remove the cover and you should see a mesh filter. Take it out and clean it good.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-20-2012, 09:42 PM   #4
Ok so please keep in mind that this is the first time I've tried to fix a dishwasher. Unfortunately there is no manual online so I'm kind of lost on where the pump and each filter is. I took off the kick plate but it just has a general electrical schematic and no help. I will be posting pics shortly. I greatly appreciate the help.
Old 11-20-2012, 09:48 PM   #5
Ok so the first one is of the spray ARM off. It does have standing water in it all around the area where the screws are. The second was a filter that is at the front right of the dishwasher. It was clean.
Old 11-23-2012, 12:23 AM   #6
Missouri Bound's Avatar
There are cleaners which you can run through the dishwasher. I would give that a try first. What also works is a glass or cup of vinegar, placed on the top rack, right side up of course. Another method is to wait until the machine is full, then pour the vinegar in the standing water. Let the machine run a full cycle. The vinegar will help clean all the tubes and orfices and may make a difference in the soapy residue issue. I would try it a couple of times, then run your normal load. Use the vinegar when the machine is empty.
Do you want it your way or the right way?
dishwasher leaving brown marks nbmech Appliances 6 08-20-2012 07:56 PM
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
White residue from my dishwasher on my dishes. Chris Woodruff Appliances 1 10-31-2011 08:21 AM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
