Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-02-2010, 08:57 AM   #1
SNC
Dishwasher leaking
Ive had this one since it was new, 5 years or less. Noow it leaks foamy bubbles out of the two lower corners. The door seal looks good but it looks a litle short. Do these things shrink ? Wonder it I can cut it at the top and slide each side down. Cant imajine much water at the top getting out.
SNC is offline   Reply With Quote
Old 09-02-2010, 09:11 AM   #2
fabrk8r
fabrk8r's Avatar
Dishwasher leaking
Post the brand and model of DW.
Some dishwashers (Frigidaire, for one) have a lower door seal that is defective and can be replaced with an upgraded version. Otherwise new perimeter seals can usually be bought and installed fairly easily.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-02-2010, 10:57 AM   #3
SNC
Dishwasher leaking
It is a Kenmore Ultra Wash cant find a number unless it is W10040710
Old 09-02-2010, 11:05 AM   #4
fabrk8r
fabrk8r's Avatar
Dishwasher leaking
There have been problems with Kenmore DW's getting sediment in the fill valve causing the valve to stay open allowing excessive water depth.
There are other possible causes. Look at this link: http://www.appliance-repair-it.com/d...r-leaking.html
Old 09-19-2010, 09:59 AM   #5
SNC
Dishwasher leaking
I did find the valve to be gummed up, thought I fixed it but I guess not. I have not tried to look down the pipe yet.
Old 09-20-2010, 09:10 AM   #6
Household Handyman
Dishwasher leaking
The "foaming bubbles" tends to lead me to ask: Are you using "automatic dishwasher" detergent in this unit or are you using regular plain old dish washing detergent, as in the type used in a sink, in it? Just had to ask. David
Old 09-20-2010, 10:40 AM   #7
SNC
Dishwasher leaking
I am using a store brand dishwasher soap, as in a generic Cascade.
Since I cleaned the valve the bubbles seem be be much less, the last time is was almost only water, where a couple times it seemed to be almost all bubbles.
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 09:49 AM
Water leaking out left side vent(?) of Dishwasher Barkley Online Appliances 8 01-14-2011 01:42 PM
Leaking Dishwasher Clean-up teamcanada Plumbing 0 06-23-2010 03:16 AM
New Dishwasher Water Line Leaking HELP! benchmarkman Appliances 4 12-13-2009 09:45 AM
leaking under sink when dishwasher on Big B Plumbing 2 06-07-2006 07:36 PM
