Dishwasher Kit - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 08:17 AM   #16
Originally Posted by oh'mike
You are hard wired---you need a romex to box connector--
Use the existing air gap---just need a hose clamp--
water line should have the angle fitting needed in the bag---
Your drain line looks long enough from here--
So the current hose connected to the air gap is fine you think?
dinosaur1 is offline   Reply With Quote
Old 12-10-2011, 08:55 AM   #17
That 96" will allow you work more easily---just make sure the extra is out of the way of the motor and you will be fine--
Do you think I need the strain relief part that isn't included.
Old 12-10-2011, 09:35 AM   #18
DIY staff
Rewards Points: 7,174
Your old hose should be fine---
I don't even know what a strain relief is---so I doubt if you need one.
Old 12-10-2011, 09:37 AM   #19
I'm confused. Do you see that grey hose attached to my new dishwasher on the back? Is that in place of the white hose lating on the ground? If it is Ill give the old
one to the person buying it.
Old 12-10-2011, 09:56 AM   #20
DIY staff
That white tube with the black angled piece looks like the drain line from the old unit---that should go with the old dishwasher---
Old 12-10-2011, 10:26 AM   #21
Okay help me understand then what old holes should be fine?
Old 12-10-2011, 10:59 AM   #22
DIY staff
The hose from the 'air gap' to the sink tail piece----the drain line on the new machine should be long enough to reach the 'air gap'----
Old 12-10-2011, 11:01 AM   #23
Ok so basically I don't keep old things from old machine
The Following User Says Thank You to dinosaur1 For This Useful Post:
oh'mike (12-10-2011)
Old 12-10-2011, 01:50 PM   #24
I need to buy a (i think its called) a cable keeper for the nm wiring for this dishwasher. Do you know they call them because I need to visit the hardware store.
Old 12-10-2011, 03:22 PM   #25
DIY staff
Cable staples and nylon tie straps are all I know---Romex is not allowed in this area --so I don't know the names of the straps ---
Old 12-10-2011, 08:22 PM   #26
DIY staff
I'm slow in the head today----the cable keeper---is the part I described above--
A-Romex(NM) to box connector.(take the one off the old machine if it's still good--)
Old 12-10-2011, 10:38 PM   #27
Actually we got it. It was the strain relief.
Old 12-11-2011, 06:27 AM   #28
DIY staff
This is why I stay out of the electrical section----I actually worked for an electrician for quite some time---but we are all conduit here---
I doubt if I've run 400 feet of Romex in my life---so I feel mighty useless in the electrical area because Romex is the world standard--and I have no experience with it--
Old 12-11-2011, 08:39 AM   #29
No worries. I appreciate the great help!
oh'mike (12-11-2011)
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 10:59 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
