Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-09-2011, 11:37 PM   #1
dishwasher kit
I'm installing my new dishwasher tomorrow. What is my best bet when it comes to buying a dishwasher kit? I plan on getting a stainless steel braided hot water supply line.
I bought this one.
http://www.samsung.com/us/appliances.../DMT400RHS/XAA
dinosaur1 is offline   Reply With Quote
Old 12-10-2011, 05:33 AM   #2
Super Moderator
dishwasher kit
Are you talking about a water line? The stainless lines are great----Many new machines require a 3/4" garden hose type adapter---that should be in the bag with the hose--some require a 1/2"x3/8" angle adapter--that should also be in the bag
Old 12-10-2011, 06:37 AM   #3
dishwasher kit
I need the entire dishwasher kit.
90 elbow, rubber connector, air gap, tube fittings, strain relief, hose clamp or power cable.
When I look at the new drain hose on the dishwasher it doesn't look long enough to me. Maybe I'm wrong.
Old 12-10-2011, 07:01 AM   #4
Super Moderator
dishwasher kit
I install a bunch of dishwashers in a year---the hose will be long enough if the sink cabinet is next to the dishwasher---
The air gap is not required in Illinois--so I don't know about that---I just loop the drain hose up to the bottom of the counter top.
Don't know what a 'strain relief' is---
Most dish washers here are hard wired using greenfield (metal flex) --If yours gets plugged in--a short 20 amp appliance cord should do----
Are you replacing an old machine or adding one to a place for the first time?
Old 12-10-2011, 07:08 AM   #5
Super Moderator
dishwasher kit
Just a tip----Make your height adjustments before you push that thing into the hole----
You will not be able to adjust the back levelers easily after it's in place---
del schisler (12-10-2011)
Old 12-10-2011, 07:12 AM   #6
Super Moderator
dishwasher kit
Another tip---the screw clips the you use to attach the machine to the underside of the counter--
If the counter top is stone and you don't want to attach to that---
The clips can be moved to the sides of the door--allowing you to secure the unit to the cabinets--not the counter top----
Old 12-10-2011, 07:29 AM   #7
dishwasher kit
Yes I'm replacing an old one. Our countertops are not stone. Should I go into Home Depot and just get a dishwasher kit? I was told I need a 3/8 MI 3/8 compression 90.
Old 12-10-2011, 07:37 AM   #8
Super Moderator
dishwasher kit
The stainless water line comes with the dishwasher angle fittings---so if your old shut off is 3/8" you should have everything needed for the water feed---if your old shut off is 1/2" you may need a 1/2" to 3/8" reducer---that is included with some hoses.too.
Is an air gap required in your area?--If not --just loop the hose up under the counter top---
Old 12-10-2011, 07:40 AM   #9
dishwasher kit
Here is what my manual says is not included. I do have an air gap.
Old 12-10-2011, 07:44 AM   #10
Super Moderator
dishwasher kit
If you can post a picture of the existing under sink set up--that would help---
Does the drain currently attach to the garbage disposal or the sink tail piece?
If the tail piece---make sure the opening is the correct size---Depot only sells tail piece adapters in a small size that requires cutting the rubber boot on the drain hose---
I always change those to the larger size (available at Menards) --Sorry--don't have the sizes in my head---look at the inlet on a garbage disposer--that is the size you want---
Old 12-10-2011, 07:52 AM   #11
Super Moderator
dishwasher kit
Look under the old machine---is it hard wired now? if so--no power cord is needed--just two or three new yellow wire nuts---
Your existing air gap and it hose should be fine---get a new one if the old one looks like it needs replacing.
The angle fitting comes with the hose---that nut and ferrule shown is not needed if you use a flex line--
Do buy a new hose clamp or two---
Old 12-10-2011, 08:06 AM   #12
dishwasher kit
Back of new dishwasher
Front of new dishwasher
Air gap
Under sink
Under sink
Dishwasher space
Old 12-10-2011, 08:10 AM   #13
dishwasher kit
Dishwasher kit from Sears. Will this work. 96 inches seems very long though.
Another pic of same kit
Old 12-10-2011, 08:12 AM   #14
Super Moderator
dishwasher kit
You are hard wired---you need a romex to box connector--
Use the existing air gap---just need a hose clamp--
water line should have the angle fitting needed in the bag---
Your drain line looks long enough from here--
Old 12-10-2011, 08:15 AM   #15
Super Moderator
dishwasher kit
That 96" will allow you work more easily---just make sure the extra is out of the way of the motor and you will be fine--
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 10:59 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
