Dishwasher Keeps Blowing Fuse - Appliances - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 06:55 PM   #1
dishwasher keeps blowing fuse
kitchenaid whisper superba keeps blowing fuses. i changed wire harness with fuse and blew again after 2 weeks. any ideas? what i can look for that is the culprit.
funkjosh is offline   Reply With Quote
Old 10-23-2012, 06:58 PM   #2
Too Short? Cut it Again!
Is it hardwired or plugged into an outlet under the sink? Might be a bad outlet or one that has a loose neutral. Is it on a dedicated circuit? Loose neutral for that circuit at the box?
Old 10-23-2012, 09:07 PM   #3
Rewards Points: 264
I'd just run a new line from the panel box to the dishwasher - mostly because I don't like fuses.
If it still trips, buy a new dishwasher.
tibberous is offline   Reply With Quote
Old 10-24-2012, 08:56 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
I assume you are talking about the fuse in the dishwasher control panel and not the house fuse correct?? If that is the case then you should replace the fuse and the door switches as a kit
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-24-2012, 11:33 AM   #5
yes fuse in control panel. replaced fuse with wire harness and blew again after 2 weeks. there is continuity at door switch when closed. the machine is either getting to hot or drawing too much current.
Old 10-30-2012, 04:50 PM   #6
breaker at panel is a little loose but not tripping (its federal pacific and ive heard they are notorious for not tripping). im wondering if that could cause fuse to blow @ dishwasher by either drawing to much current or voltage drop? anyone?
Old 10-30-2012, 06:35 PM   #7
#1 HAWKEYE FAN
model # ? Did you replace door switches?
Old 10-30-2012, 07:26 PM   #8
dont have model number but its a kitchenaid whisper superba. what would make the door switch blow fuse?
the breaker the dishwasher is hooked up will become unseated a bit on bus bar.
Old 10-30-2012, 07:27 PM   #9
Loose neutral at the breaker panel? Or, as you suggested a possibility, a bad or lazy breaker?
Old 10-30-2012, 07:49 PM   #10
#1 HAWKEYE FAN
if you get me a model# I can tell you exactly why the door switches will blow the the control panel fuse. Many models of KA and Whirlpool dishwashers had a problem with door switches over heating the wires and blowing the fuse. Get me the model# and I will look it up for you.
The house fuse or circuit breaker is not what is causing it.
Old 10-30-2012, 08:06 PM   #11
#1 HAWKEYE FAN
one more thing to check. Disconnect the power from dishwasher and ohm out the heating element, disconnect one side first. If it ohms out ok then check to see if it may be shorting to ground.
Old 10-30-2012, 08:16 PM   #12
ohmd out heating element. disconnected both ends. measured at 17.5ohms.
measure short to ground? continuity from heating element to dishwasher frame?
Old 10-31-2012, 12:32 PM   #13
model # KUDS25SHBL1
Swamp cooler keeps blowing buss fuse on low speed GRed Electrical 14 07-08-2012 07:43 PM
Rhem Heat Pump low voltage fuse keeps blowing z4racer HVAC 3 02-29-2012 08:02 PM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 05:22 PM
Trane XR90 keeps blowing fuse McTreez HVAC 1 11-01-2010 05:56 AM
Blowing fuse kenneth floyd General DIY Discussions 4 08-04-2009 01:27 PM
