Dishwasher Installation Blues - Appliances - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 06:51 PM   #1
Dishwasher installation blues
I installed my dishwasher the other week and there is a gap from the top of the dishwasher to the counter top. It isn't noticeable unless your a little kid but you can see the insulation. Anyone have any solutions to my problem? I know that I can raise the feet but then it seems to tilt, any help would be appreciated, thanks.
lexnupe is offline   Reply With Quote
Old 03-13-2013, 07:34 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Lex,
no rear feet on the unit? Normally you have to adjust the front feet to raise it up. If yours doesn't raise in the back, You could cut some shim material to set under the rear supports. Make the thickness the same as the amount you have to raise the front to get rid of the gap.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-13-2013, 08:26 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
whirlpool family dishwashers only have wheels on the back and levelers on the front, but those wheels also have 3 different heights by removing the wheel and putting it in the next screw hole, but you may have to shim it with thins boards. Theres nothing worse than a tilting dishwasher.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Dishwasher Installation champy2008 Appliances 4 01-07-2009 10:06 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
