Dishwasher Installation - Appliances - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 10:38 AM   #1
champy2008's Avatar
I recently purchased a Kenmore Elite dishwasher from a Sears Outlet. The outlet sells returned and refurbished equipment that is essentially "new". When I removed the old dishwasher I noticed there was insulation around the top and sides. My new washer did not come with any insulation. My question is do I need this insulation for my new washer?
champy2008 is offline   Reply With Quote
Old 01-07-2009, 10:47 AM   #2
Some dishwashers have the insulation under an outer shell. Can you take a picture of it?
jerryh3 is offline   Reply With Quote
Old 01-07-2009, 10:52 AM   #3
champy2008's Avatar
I'll get some pictures. Is the insulation for sound dampening or is it to protect the cabinets from heat. I have run it once and it doesn't seem to have either problem. I just want to make sure I am not leaving the door open for trouble down the road.
Old 01-07-2009, 10:55 AM   #4
Learning by Doing
Leah Frances's Avatar
This installation is primarily for deadening the noise the dishwasher makes. To some extent this is what separates the $$ from the $$$$ in dishwasher models.
Not only would I re-use the old installation I would consider adding more. I dynamatted my steel tubbed dishwasher, as well as adding foam to the cabinet/wall/counter junctions - now it's whisper-quiet.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-07-2009, 11:06 AM   #5
champy2008's Avatar
Thank you. There is a foam or rubber matting applied to most of the outside of the washer (about 3/8" thick). Unfortunately I threw out the old insulation. It seems to be very quiet, it's a fairly expensive unit. I will probably add some more insulation anyway.
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
If you've never had a dishwasher before... Beth777 Electrical 5 09-16-2008 03:44 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 05:28 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
