Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-31-2010, 12:44 PM   #1
dishwasher install question
I recently completed a house remodel and we moved in over the weekend.
We renovated the kitchen but kept all the old appliances.
I notice on dishwashers that there are clips on the front top that would appear to be used to attach to the under counter. When I pulled the machine out these were not used and when I reinstalled I also did not use them.
Now comes the obvious problem(didnt seem so obvious when I installed it) of the machine wanting to tip out when the drawers are open with dishes in them.
How would I attach the clips to the corian counter? I would imagine screws, maybe small tapcons?
Any advice is greatly appreciated.
Thanks.
jegolopolli is offline   Reply With Quote
Old 08-31-2010, 01:11 PM   #2
fabrk8r
fabrk8r's Avatar
See if this link helps...
http://www.appliance411.com/faq/builtinDW.shtml
The stove anti-tip brackets sound like a good idea!
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-31-2010, 01:37 PM   #3
Awesome, thanks!
Those brackets will be perfect.
Old 08-31-2010, 02:53 PM   #4
You will also want to level your unit front to back while compensating for the clips.Otherwise drainage could be a problem
Chemist1961 is offline   Reply With Quote
Old 08-31-2010, 02:54 PM   #5
The dishwashers I have installed (all four of them) had the option to attach at the coutertop or on the sides into the adjacent cabinet. If drilling into corian sounds like a bad idea, then I suggest side mounting as an alternative. Does your manual not show this option?
oberkc is offline   Reply With Quote
Old 08-31-2010, 03:32 PM   #6
There is no manual. I have yet to look online for it.
There does not seem to be anywhere for a side mount, though I didnt really investigate it.
Dishwasher wiring question jimithing78 Electrical 6 05-11-2010 07:03 PM
Cultured Stone Veneer Install Question wifepleaser Building & Construction 3 05-01-2010 05:28 AM
Humidifier Install Question - Inside A Coil OK? dwolek HVAC 1 12-21-2009 01:37 PM
Mannington Flooring Installation Question marlon71usa Flooring 3 12-10-2009 04:24 PM
Receptacles Behind Gas Range Install - Question IIchrisII Electrical 4 07-27-2009 09:37 PM
