-   -   Dishwasher inlet valve replacement issue (http://www.diychatroom.com/f47/dishwasher-inlet-valve-replacement-issue-178471/)
odieman99 04-30-2013 06:36 PM
Hey all,
new to the forum and new to home ownership and repair so please forgive the lack of experience question.
Anyway, I have a Frigidaire dishwasher that is at least 15 years old. Based on Googling around I think I need to replace the water inlet valve since I get no water into the dishwasher but the motor runs. I found a great Youtube video on how to do this. I turned off the water and began to unscrew the inlet pipe/hose and water began leaking out, which I was told was normal to have a little...so I kept unscrewing and it just kept flowing. I didn't take it all the way off out of fear that I would have a small flood in a few minutes, so I screwed it back on. I double checked to make sure the water was off and it was. I eventually turned off water to the whole house just to be certain. Then I tried again to have the same problem. Anyone know what I'm doing wrong? Any insight is much appreciated.
Jason
oh'mike 04-30-2013 07:44 PM
I moved this to 'appliances'---Be patient--appliance questions seem to get answered in the wee hours of the morning----Mike-----
hardwareman 05-02-2013 12:04 AM
turn off main water valve, go to the lowest level faucet in your house and turn it on go to any other faucet turn it on . This will bleed all the water from your lines.
odieman99 05-02-2013 01:06 AM
Great advice, did that and it stopped the leak, but now the faucet that I turned on to bleed the water won't stop streaming water! It's a slow stream, but why isn't this stopping?? It's been a good 30 mins...This is the biggest pain in the butt for a small job...
HELP!
hardwareman 05-02-2013 11:53 AM
LOL, yeah that sometimes happens when you turn off old valves that have not been turned in a long while. Now unfortunately you will probably have to replace that shutoff
BirdSlapper 05-02-2013 01:46 PM
Would he have to have the city shut the water off in order to do that?
I have an idea of how to get the dishwasher back on track, but he must work quickly! :jester:
Use a braided stainless line with compression fittings on each end. Hook up the inlet valve, connect the line to the inlet and very quickly cut off the copper pipe! Use a stainless inline valve with a slip fitting and towels to soak up the water.
