Dishwasher Hook-up - Appliances - DIY Chatroom Home Improvement Forum
Old 08-21-2008, 01:46 PM   #1
DDY
dishwasher hook-up
Hi There,
I just got brand new frigidaire dishwasher and i am trying to figure out how to hook it up. The plumbing part would be easy but the electric connection part is killing me... The dishwasher came only with drain hose, there is no power cord or anything. Also I have no clue that previous home owner had any dishwasher or not.
When I check the installation instruction as I understood i have to make connection from the junction box. But, does this connection have to be with wiring from circuit box or can I purchase any diswasher power cord to connect it. ???????
I really need your advice
I appreciate your help, have a good day
DDY is offline   Reply With Quote
Old 08-24-2008, 12:15 PM   #2
jeff1's Avatar
Hi,
Normally/most common is hard wired.
Can install a cord if there is an outlet to plug it into.
This may help....
http://www.popularmechanics.com/how_...c/1276406.html
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 08-24-2008, 08:48 PM   #3
Here in Canada dish washers always come equipped with a power cord and 15 amp plug!
It must be required by law, as all our appliances are US made.
Old 09-09-2008, 07:53 PM   #4
Most are hard wired,they can be corded but the cord must be rated for a dishwasher,a 3 prong grounded outlet on a 15-20amp separate circuit,read the electrical requirements in the installation instructions and follow them to the tee..
gotboost is offline   Reply With Quote
Old 09-09-2008, 09:39 PM   #5
Electrician
The biggest code violation I see is dishwashers hardwired with no disconnect. I prefer the plug and cord method with a receptacle under the sink.
chris75 is offline   Reply With Quote
Old 09-09-2008, 09:48 PM   #6
How about a ground fault receptacle?
Old 09-09-2008, 09:50 PM   #7
Electrician
Only if your buying No its not required by code, nor would I waste someones money on it.
Old 09-09-2008, 10:04 PM   #8
Hard wire
I installed one a few years back. I forget whether it whether it was standard 120 or 240 volt. If it is a standard 120 you can run a line form another outlet and terminate it in a junction box behind the dishwasher and hardwire it. In US I don't think many come with a cord so they can get you for the installation charge since most people don't want to venture into the hardwiring.
fconticello is offline   Reply With Quote
Old 09-10-2008, 12:02 PM   #9
Safest is with either cord or hard wired to a GFI protected circuit. If its from a circuit in the kitchen it may already be GFI protected. Check your code office to be sure you're doing it right.
dac122 is offline   Reply With Quote
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
Kenmore Ultra Wash Dishwasher mystery rtyui2 Appliances 3 05-29-2008 10:35 AM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 08:19 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
