Dishwasher Help - Appliances - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 09:19 PM   #1
Dishwasher Help
Model # KUDK01ILBS2
Kitchen Aid 6yrs old
Hello. About 6 months ago my dishwasher wouldn't clean the top rack of dishes..I figured out that there was no water coming out of the top sprayer, The Chopper Assembly was clogged up.. I pulled it out and cleaned it up, Problem solved...But, every 2 months It does the same same thing even though we try the scrap off the plates before we put them in now but it still clogs up every few months.. My question is, Why did it work fine for over 5yrs, and now it clogs up in a few months?
Thanks for any help
ChickenWing is offline   Reply With Quote
Old 09-04-2012, 09:03 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
what does your main pump filter look like? My first thought would be that you need to scrape off your dishes a little better before loading the dishwasher, dishwashers do ok with small food paarticles but when there is excessive bits of food going through them the filters plug in no time. Your chopper blade is ok and the screen behind it indicates lots of food bits being run through it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-04-2012, 10:57 AM   #3
Thanks hardwareman.. I don't know about the main pump filter, didn't even know there was one..how/where would I check to see it?
Old 09-04-2012, 01:55 PM   #4
I have a Kenmore Elite Front Loading Washing Machine and it has started leaking water inside the rubber mount after the unit has completed it cycle...What is causing this...The model #42926-000...TYPE #199-HKP-702-GT...
I appreciate any advice or help anyone can give me...
lc116235 is offline   Reply With Quote
Old 09-04-2012, 09:36 PM   #5
#1 HAWKEYE FAN
your filter would be that piece you take off after the spray arm assy. It should be a fine mesh that traps a majority of your food particles
Old 09-09-2012, 10:59 AM   #6
Thanks alot hardwareman,
I don't believe I have seen that, I haven't taken anything like that off the 3 other time Ive cleaned the chopper blade...Would you have a pic or link to said main pump filter??
Old 09-11-2012, 02:08 PM   #7
Bombastic Idiot
notmrjohn's Avatar
lc,could be you just need areal good cleaning around and under the seal and contact surfaces, you wouldn't beleave the stff that build up in there. It can be hard to see in between bottom of door and cabinet, strong flashlight, mirror and limber neck are useful. You may need a new gasket. but hop over to here and take a look. Bosch Dishwasher leaking along bottom seal of door
Here's alink for you, chicken, http://www.appliancepartspros.com/pa...odel_id=504793 While you're there see how much a new chopper and screen costs, six years old, may be worth replacing if cheap enuff. Trouble with those sites is you buy a 50 cent part and pay 10 bucks for shipping. It's like those As Seen on TV scams, both of he gadgets and all the extra Free cra...stuff is guaranteed money back, but the two way shipping and handling is more than the 19.95 you get back.
Hey, i just saw, you got a 4 arm sprayer. Never saw on of those. I sure hope its held on with a screw, I'd hate to have to send you over to the Alice's Dishwasher thread with the diagrams and circles and arrows and a paragraph for each one describin what each one was.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 07:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
