Dishwasher Drain Valve Opening - Appliances - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 05:33 PM   #1
Dishwasher drain valve opening
Hey all - hoping that someone can point me in the right direction for a DW repair.
After my dishwasher fills the tub and the motor kicks on the water pressure is forcing the drain valve/gate open and the thing will drain until the water level in the tub is way too low.
Still happens when I disconnect the power leads to the drain solenoid.
I jammed some cardboard in the drain solenoid to hold the valve shut. Worked normally.
What should I take a look at to remedy this?? This is a diagram of my machine: http://www.appliancepartspros.com/pa...model_id=44099
Thanks!
WallyWoggle is offline   Reply With Quote
Old 01-12-2011, 08:44 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
look at the spring on the flapper, is it still attached or did it break? if it is still attached you probably need a new plapper
hardwareman is offline   Reply With Quote
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 04:37 PM
kenmore dishwasher cut out, won't drain, no power jess1974 Appliances 3 12-28-2010 06:45 PM
valve retrieval in a drain houston81 Plumbing 1 07-07-2010 04:33 PM
advice in removing plastic drain valve from water heater darsunt Plumbing 1 06-15-2009 04:30 PM
