Dishwasher Drain Check Valve? - Appliances - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 05:26 PM   #1
Rewards Points: 87
dishwasher drain check valve?
I just installed a new ge dishwasher and when I hooked up the drain hose to the dishwasher I noticed a rubber piece blocking the hole, instead of reading the manual I just cut it off. Well turns out the was suppose to stay on. Did I mess up the dishwasher and have to get a new part or can I run it with out the rubber check valve?
Roundeye is offline   Reply With Quote
Old 03-23-2012, 09:36 PM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
That is a backflow preventer to keep the drain water from returning to the tub. If you're draining to a disposal or some point higher than the hose connection you'll get dirty drain water back in the sump without this piece. You probably should replace it.
Thunder Chicken is offline   Reply With Quote
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 04:37 PM
Noisy sump pump check valve deltav700 Plumbing 2 10-01-2010 08:21 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
