Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-05-2009, 01:49 PM   #1
Question
Dishwasher dispenser broken--Is it necessary to fix it?
I have a Kenmore Elite dishwasher. The detergent dispenser is broken. It looks as though the plastic lip of the door has broken off and it won't stay shut. The rinse aid half still works fine.
The part will run a minumum of $60 if I order it myself on-line. YIKES!
Should I fix it? Is there some fabulous reason I should?
I have just been putting in detergent like usual and running it. Dishes are coming out clean--as far as I can tell!
$60 for a cheap plastic part is outrageous, in my opinion.
Thanks.
queenofthehouse is offline   Reply With Quote
Old 02-05-2009, 02:11 PM   #2
Mine on my Bosch only pops open and spills soap granuals. I have been inside the door and it is a nasty looking sharp edged dispenser which I would not want to change...the door is not a fun spot to work.
If you are using cubes you might check the results putting them in the cutlery basket or not
Chemist1961 is offline   Reply With Quote
Dishwasher rinse aid dispenser Joe F Appliances 12 02-01-2012 06:24 PM
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 09:19 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 05:28 PM
