Dishwasher Bi-metal Fuse - Appliances - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 04:12 PM   #1
Do something
D'Brie's Avatar
Dishwasher bi-metal fuse
In my two year old Kitchen Aid dishwasher (model KUDC03IVWH3) the bimetallic fuse keeps blowing. Can't seem to find the cause. Anyone have any ideas? Nothing else is wrong, all functions work as usual. Thanks for the help!
D'Brie is offline   Reply With Quote
Old 02-02-2013, 04:28 PM   #2
Rewards Points: 83
Is this a thermostat or a fuse? What does it look like? Part number? What happens when it goes? Current draws? Does it fail after a few months or immediately? Is it when you start a cycle?
Need to be more descriptive. Saying it "blows" and asking why could be a million things.
Protocol. is offline   Reply With Quote
Old 02-02-2013, 04:34 PM   #3
Do something
D'Brie's Avatar
It's the bimetallic fuse. Diameter of a dime with two prongs coming off back for controls wires to attach. It's located in the top of the door on control panel. First on blew after 1.5 years, second one in two weeks of use. Seems to fail somewhere in mid-cycle of normal wash. Part number W10344801
Old 02-02-2013, 04:43 PM   #4
Do something
D'Brie's Avatar
Attached photo
Here is an attached photo showing bimetallic fuse, panel and a jumper wire.
Old 02-02-2013, 04:57 PM   #5
Rewards Points: 13,270
http://www.repairclinic.com/RepairHe...ne-Repair-Help
Check out the top area where it says live help. It's better if you try it during the day.
D'Brie (02-02-2013)
Old 02-02-2013, 05:02 PM   #6
Rewards Points: 83
That looks like a thermal bi-metal. If it is in fact a fuse, then there has to be something causing high current draw during the cycle. The fact that it's not blowing right away or takes a few cycles would make me think it's possibly a motor or pump that has a hard time starting or a bad bearing. Check the manual with the unit, sometimes there is one behind the panel on the bottom, that should be able to tell you how to run a test cycle or test individual components. Then I would check current draw on each to see if any are higher than normal. Could also be a sticking relay on the board, but I think it would happen more often than that.
The Following User Says Thank You to Protocol. For This Useful Post:
D'Brie (02-02-2013)
Old 02-04-2013, 08:59 AM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
replace the door switches, common problem
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-19-2015, 07:13 PM   #8
Rewards Points: 187
I have a whirlpool dishwaser that seems to be close to identical to the kitchen aid unit described above. I've been having the same issue. Bought the unit 2.5 years ago. Fuse kept blowing repeatedly. Initially they kept replacing the fuse under warranty. Then they replaced more electrical components and it was fine for around 2 years. Now the thing blew again this week.
Any ideas?
What is the theory with the door switch causing this?
Thanks!
Jaxx is offline   Reply With Quote
Old 03-21-2015, 09:20 PM   #9
#1 HAWKEYE FAN
spade connectors on the switches get hot causing above normal amperage draw. The new kit will have new switches and a terminal block that the wires connect into rather than spade terminals
Old 03-22-2015, 10:15 AM   #10
Rewards Points: 2,386
Got rid of my whirlpool because of that. The last time it blew they gave me an after market extension wire kit to move the thermal fuse a little further away from the heat source. That lasted another year. I came to the conclusion that there was no fix for it other than keeping simply bypassing it all together... which is probably a little too unsafe to do.
That and numerous other bitter disappointments over the whirlpool machine, and I finally yanked and put in a Bosh machine. That solved the problem. Best machine I have EVER owned.
Bob Sanders is offline   Reply With Quote
Old 03-22-2015, 04:24 PM   #11
Rewards Points: 187
And you are referring to the spade connectors on the door switch or on the fuse itself? When the unit came back after the 3rd fuse failure I noticed that they changed some wiring (not on the door switch though) and they added 2 terminals that the fuse wires into, it still has spade connectors on the fuse though. Would you have more info on what needs to be replaced and what it looks like? Thanks for your help so far!
Which heat source are you referring to?
Old 03-27-2015, 01:00 PM   #12
Rewards Points: 187
Could someone help me with this? My dishwasher has been sitting dead for 2 weeks now.
Thanks!
Old 03-27-2015, 03:54 PM   #13
#1 HAWKEYE FAN
part # W10258275 bi metal fuse kit. Comes with new fuse and new wires
Old 03-31-2015, 11:53 AM   #14
Rewards Points: 187
This kit was already installed the last time it was in for service, but it failed again. I read somewhere that the location where the fuse gets placed is also critical as heat makes it trip. But there is only one location where it snaps in. I'm not sure how this could be corrected?
Back in 2013 you were saying something about the door switch needing to be replaced and that it was a known problem. Is this another issue that needs to be fixed? Would you have more info about this?
Thanks!
Old 03-31-2015, 12:36 PM   #15
#1 HAWKEYE FAN
location has nothing to do with it. Never relocate a safety device unless manufacturer instruction tell you to do so. My advice would be since its lasted 2 years go ahead and put the kit on again. This has long been an issue with Whirlpool dishwashers. The other problems that could cause the failure are a temp sensor not working properly, the heating element drawing too much amperage (need to replace) or the motor drawing too much amperage.
Recommendations for roof type when reroof daluu Roofing/Siding 24 12-07-2012 03:23 PM
Whirlpool Dishwasher TCO Blown - Regular Fuse? ddawg16 Appliances 4 11-05-2012 10:50 AM
dishwasher keeps blowing fuse funkjosh Appliances 12 10-31-2012 12:32 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 01:21 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 06:54 AM
