Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-26-2010, 06:02 PM   #1
dishwasher
How to remove spray arms Maytag dwu7400abx
ddddsmith is offline   Reply With Quote
Old 09-27-2010, 04:36 AM   #2
No Hacks Allowed!
dishwasher
Click this link for a Complete Diagram and Parts List for Maytag Dishwasher DWU7400ABX
See the two diagrams attached below that illustrates the upper and lower spray arms.
Click the generic advice link How to Remove and Replace Dishwasher Spray Arms, or read the copy-and-pasted info below:
Removing and replacing a dishwasher spray arm ***GENERIC ADVICE***
Note:
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Water is forced through the spray arms of a dishwasher by the unit's pump and motor assembly. The force of the water propels the spray arms, spraying water and detergent onto the dishes on the dishrack. Depending on your model, you may have only one spray arm located on the bottom of the dishwasher, or you may also have an upper spray arm located at the top of the unit above the upper dishrack. There may or may not also be a plastic tower extending from the center of the lower spray arm, whose purpose is to spray an additional blast of water at the dishes.
Remove the lower dishrack from the unit. If your dishwasher has a spray tower in the center of the spray arm, remove it now by unscrewing it with your hand. You should see a bolt in the center of the spray arm. Remove the bolt and then remove the lower spray arm by pulling up on it. If your particular spray arm is not held in place with a bolt, lift up on the spray arm to remove it from the unit. You may need to rock it back and forth a little to help ease the process.
If there are any washers used with your spray arm, make sure you return them in the same order they came off.
If you are replacing the spray arm, simply discard the spray arm you have just removed, and insert a new one in its place. To clean your spray arm, soak it in warm, soapy water. Rinse it clean with a high pressure spray of water. Return spray arm to dishwasher.
Pump & Motor Diagram and Parts List for Maytag Dishwasher DWU7400ABX [LOWER SPRAY ARM ②]
Tub Diagram and Parts List for Maytag Dishwasher DWU7400ABX [UPPER WASH ARM ㉗]
NoHax is offline   Reply With Quote
Dishwasher powder instead of salt - Doh! Bottletops General Discussion 0 03-03-2010 12:06 PM
Thinking about installing a dishwasher kossuth Appliances 1 09-23-2009 11:05 AM
Dishwasher installation Andy Griffith General Discussion 3 03-02-2009 07:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 05:28 PM
