Dish Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 04:41 PM   #1
dish washer
dishwasher not draing well?
matt stobierski is offline   Reply With Quote
Old 05-15-2012, 04:42 PM   #2
pictures help, does it drain into a disposal?
mcfarton is offline   Reply With Quote
Old 05-17-2012, 07:14 AM   #3
If you can paste here the pictures for that particular problem then really appreciate.
Well right now I couldn't find the problem exactly what is its cause. and what could be the best remedy for that.
nobeel25 is offline   Reply With Quote
Old 05-17-2012, 08:44 AM   #4
DIY or die !
Rewards Points: 77
What brand/model?
your drain hose/pump are probably clogged. Start by pulling the impeller offer (some of the top nuts are reverse thread) , then remove all the plastic pieces you can SLOWLY without breaking them. Every brand is VERY easy to break !
Pull out whatever screen is in your way to access the "chopper" blade. Check to make sure this is not bound. Clean out ANY garbage in the sump that you find. Run it.... still not draining correctly? Go to the disposal/sink. Pull the hose off and look for BOOGERS. See if you can blow through it. (even though there is a check valve you should stil be able to blow a SMALL ammount).
Free? If not you probably have a clogged hose. Pull the dishwasher out and pull the drain hose off to check for obstruction.
lewisthepilgrim is offline   Reply With Quote
Installing a new Dish Washer mhp8982 Appliances 2 12-28-2011 05:25 PM
Dish washer hook up el44 Electrical 3 07-24-2010 03:48 PM
Dish washer door gasket deck hand Appliances 7 04-08-2008 08:31 PM
Dish washer replacement 68MHJCs Appliances 1 02-08-2008 01:20 PM
Is it possible I have a 220 running to my dish washer? aljanney Electrical 25 02-15-2007 10:08 PM
