Dish Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 10:06 AM   #1
Dish washer
My dishwasher does not dry my dishes completely. It did in the past but I have made sure to keep drying aid in the dispenser. In the past it would release steam through the vent, now it does not. I think that's the problem but I do not know how to correct that. Your help is greatly appreciated.
rodeothor is offline   Reply With Quote
Old 04-07-2012, 12:01 PM   #2
the heating element may be shot. I would get an appliance person to look at it.
Old 04-07-2012, 01:02 PM   #3
Dishwasher
It heats but the steam does not escape.
Old 04-07-2012, 02:45 PM   #4
Not to be insulting here but is there an air dry button on it somewhere? My kids found mine before I did....
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
rodeothor (04-12-2012)
Old 04-07-2012, 02:52 PM   #5
Rewards Points: 27
Since this is a new problem I'd suggest that the unit is not draining properly and water is still at the bottom when the cycle is finished. Could be a couple of things. First, check to see if the filter at the bottom of the dishwasher is not full of food particles. If that's clean, it could be the pump is wearing out and not doing it's job.
SeeDBee is offline   Reply With Quote
The Following User Says Thank You to SeeDBee For This Useful Post:
Old 04-07-2012, 08:23 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
2 possible problems. If your unit has a fan assist dry cycle the fan may be bad, if it does not have fan assist then the vent in the door may be plugged
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Old 04-12-2012, 08:29 AM   #7
Smile
Dishwaher
If it has a fan should it be marked on the panel? In the past the steam did come out quite noticeably. On the other hand, I considered the door filter. Mine is black and seems to be deteriorating. I attempted to removi think e it by prying it out with know success. It might be a combination of the both. Great advice guys and girls!
I will start with the uses manual to see if it has a fan. Then I will pursue how to remove the filter.
My dish washer just stoped working Tabatha295 Appliances 9 10-19-2011 07:46 PM
Dish washer not cleaning properly cliffordjuli@yahoo.com Plumbing 5 10-19-2008 06:47 PM
Dish washer door gasket deck hand Appliances 7 04-08-2008 08:31 PM
Is it possible I have a 220 running to my dish washer? aljanney Electrical 25 02-15-2007 10:08 PM
dish and clothes washer drainfield rosiesunimind Plumbing 1 02-11-2007 04:41 PM
